Cisco ACE 4710 delay
mohamed fayz
Hai,
Good Day.
I had configured cisco ACE 4710 in active standby mode ( 2 ace load balancer) in one ar mode, which is physically placed on a DMZ segment, behind firewall(Palo Alto ).
Now, i load balanced 2 EMS servers both from internally and externally using one arm mode. |When i try to access these servers from internally using ACE, its working fine. But when i am accessing this from externally, it is getting some delay, after it works. I had configured stickeness in ACE, since the servers running some additional critical appliactions.
Please help me if you have any idea about this!!
Fayz
Kanwaljeet Singh
Hi Fayz,
I did give a try and it opened up without any problem. Normally accessing a server directly is faster than accessing it through LB since you have an extra HOP and it also depends if the connection is being forwarded or being proxied.
For me it worked fine, i mean i didn't get considerable delay and i tried twice.
Also, i see the original request is being redirected by server and client has to come again with URL before the final page loads.
GET / HTTP/1.1
Accept: application/x-ms-application, image/jpeg, application/xaml+xml, image/gif, image/pjpeg, application/x-ms-xbap, application/x-shockwave-flash, application/vnd.ms-excel, application/vnd.ms-powerpoint, application/msword, */*
Accept-Language: en-US
User-Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; InfoPath.3)
Accept-Encoding: gzip, deflate
Host: 78.100.95.13:8090
Connection: Keep-Alive
Cookie: ASP.NET_SessionId=y5dfk5ehyonunv55z0qkga55; sldetect=Y
HTTP/1.1 302 Found
Cache-Control: private
Content-Type: text/html; charset=utf-8
Server: Microsoft-IIS/7.5
X-AspNet-Version: 2.0.50727
X-Powered-By: ASP.NET
Date: Tue, 28 Aug 2012 07:37:12 GMT
Content-Length: 131
GET /SignIn.aspx HTTP/1.1
HTTP/1.1 200 OK
Content-Encoding: gzip
Vary: Accept-Encoding
Content-Length: 12331
Also, i still don't think redirection from server should cause noticeable delays. If the delays are considerable then we need to check if ACE is causing the delay or not and capture on ACE itself can show the time difference between the ingress and egress packets.
Also, ensure that you are not proxying the connection if you don't need it.
Kanwal
6 Replies 6
mohamed fayz
The server public IP is  http:78.100.95.13:8090. Please have a try also
Hai,
Good Day.
Fayz
Kanwaljeet Singh
Hi Fayz,
GET / HTTP/1.1
HTTP/1.1 302 Found
Content-Length: 131
HTTP/1.1 200 OK
Kanwal
Dear Kanwal,
As you told, server is redirecting the URL , but once a new pc is trying to conenct the server via the abouve url, it is getting delayed initially , after first successfull attempt, then it is working fine without any delay. if we are trying to connect again from the same pc using the url , page is getting faster. Can you please advise???
    also, how can we check from the ace itself, if it is causing the delay????
Hi Mohamed,
Please share your configuration and if possible take simultaneous captures on both sides of the ACE showing the delay
Cesar R
ANS Team
--------------------- Cesar R ANS Team
Hi Mohammed,
If you look at the content length. For the first time it has to get total Content-Length: 12331"
If you look at the packet count it consumes approx 130 packets to finish this transaction. If you look at the rate of transaction it is .021 ms. So I would say that it is not ACE which is causing delay but it is because of size of the content.
The same delay does not occur for the second time because the content is served from cache. Hope that clarifies your concern.
Ajay Kumar
