Cisco ACE with 2 bridge groups.
kholst
Is ti possible to configure the ACE with 2 bridge-groups. I for now have the following configuration at this works fine :
peer hostname ace-2
login timeout 0
hostname ace-1
boot system image:c6ace-t1k9-mz.A2_1_2.bin
clock timezone standard CET
access-list BPDU ethertype permit bpdu
access-list client-traffic-26 line 10 extended permit tcp any host 10.0.26.100 e
q www
access-list server-traffic-26 line 20 extended permit ip host 10.0.26.10 any
access-list server-traffic-26 line 21 extended permit ip host 10.0.26.11 any
rserver host test-1
ip address 10.0.26.10
inservice
rserver host test-2
ip address 10.0.26.11
inservice
serverfarm host test
rserver test-1
inservice
rserver test-2
inservice
class-map match-all L4_VIP_ADDRESS_CLASS
2 match virtual-address 10.0.26.100 any
class-map type management match-any Remote-Access
description Remote Management
2 match protocol telnet any
3 match protocol ssh any
4 match protocol icmp any
policy-map type management first-match Remote-Management-Allow
class Remote-Access
permit
policy-map type loadbalance first-match L7_VIP_LB_ORDRE_POLICY
class class-default
serverfarm test
policy-map multi-match L4_LB_VIP_POLICY
class L4_VIP_ADDRESS_CLASS
loadbalance vip inservice
loadbalance policy L7_VIP_LB_ORDRE_POLICY
loadbalance vip icmp-reply active
loadbalance vip advertise active
service-policy input L4_LB_VIP_POLICY
interface vlan 2
ip address 10.0.1.11 255.255.255.0
alias 10.0.1.13 255.255.255.0
service-policy input Remote-Management-Allow
no shutdown
interface vlan 26
bridge-group 26
access-group input BPDU
access-group input client-traffic-26
no shutdown
interface vlan 626
bridge-group 26
access-group input server-traffic-26
no shutdown
interface bvi 26
ip address 10.0.26.2 255.255.255.0
alias 10.0.26.4 255.255.255.0
peer ip address 10.0.26.3 255.255.255.0
no shutdown
ft interface vlan 504
ip address 172.30.254.13 255.255.255.252
peer ip address 172.30.254.14 255.255.255.252
no shutdown
ft peer 1
heartbeat interval 300
heartbeat count 10
ft-interface vlan 504
ft group 1
peer 1
priority 105
associate-context Admin
inservice
ip route 0.0.0.0 0.0.0.0 10.0.26.1
This also works fine but only when the default-route is in the config.
Then my question is how I add another BVI and vlan for client & server traffic.
That could be vlan 27, vlan 627 and bvi 27 with ip add 10.0.27.2/24
I can't have 2 default routes :)
Regards Kim
Kim
Default gateway in bridged mode is not relevant to the Loadbalanced trafic. In bridged mode your real servers point to upstream L3 device (router/MSFC/Firewall).
Default gateway is only needed for ACE originated Management traffic (logs, snmp...).
Thats the reason why your deafult gateway should be pointing towards the management VLAN.
In order to ensure that the server responses should go back to the same client Vlan where the request was recieved use "mac-sticky" under each client vlan.
I would also suggest creating a Dummy rserver with Gateway IP. This will ensure that ACE will constantly resolve ARP for the gateway and the ARP entry for gateway will not timeout on ACE.
Syed Iftekhar Ahmed
5 Replies 5
Yes
As long as your vlans are different
you can have multiple bridge groups.
You cannot share vlans in bridge mode.
Syed Iftekhar Ahmed
Ok, thats whar I thought. But if I remove the default-gatewy I have configured or chage it to the management interface 10.0.1.1 the LB dosen't funktion any more.
The servers are placed in vlan 626 and hav FWSM as default gateway.
Any idea ?
Ragards Kim
Kim
Syed Iftekhar Ahmed
HiSyed,
Thanks, I'll try it out.
Regards Kim
Hi Syed.
mac-sticky fixed it.
Thanks.'
Regards Kim
