Cisco WAE-674 " memory size does not match with model type " Alarm
vijay.ghalote
Hi All,
I am getting memory size does not match with model type" alarm in Cisco WAE-674 Appliance. Attached is the required information.Waiting for your kind response.
Nicolas Fournier
Hi Vijay,
A 674 is supposed to have either 4 or 8 GB of RAM as you can see from the data sheet:
http://www.cisco.com/en/US/partner/prod/collateral/contnetw/ps5680/ps6474/product_data_sheet0900aecd80329e39.html
In your case it has 6Gb:
6144 Mbytes of Physical memory.
Detailed Memory Device (DIMM) configuration
        Size              Locator             Position        Serial Number
     1024 MB               DIMM 1               Bank 1        Not Specified
     1024 MB               DIMM 4               Bank 1        Not Specified
     2048 MB               DIMM 7               Bank 2        Not Specified
     2048 MB              DIMM 10               Bank 2        Not Specified
You'll need to either remove the 2 1Gb modules you have or replace them with 2Gb module to have it working.
Nicolas
Hi Nicolas,
Thanks you so much for your time and support.
Vijay
Natalie Ramirez
You do have the option of having either 4 or 8 GB in that model, but definetely opt for the 8GB, the cost of 2-2gb pc2-5300 memory chips is very cheap.
674-4GB - 2000 tcp connections and 45Mbps WAN bandwidth
674-8GB - 6000 tcp connections and 90Mbps of WAN bandwidth
