Configuring ACE 4710 for Load Balancing Speech servers
rdancy123
Hello, I'm configuring ACE 4710's for the first time and I want to load balance my Nuance speech servers on port 554. Here's my configuration on ACE01:
hostname ace471001
interface gigabitEthernet 1/1
  switchport access vlan 1000
  no shutdown
interface gigabitEthernet 1/2
  shutdown
interface gigabitEthernet 1/3
  shutdown
interface gigabitEthernet 1/4
  shutdown
access-list ALL line 8 extended permit ip any any
rserver host nss01
class-map type management match-any remote_access
  2 match protocol xml-https any
  3 match protocol icmp any
  4 match protocol telnet any
  5 match protocol ssh any
  6 match protocol http any
  7 match protocol https any
  8 match protocol snmp any
policy-map type management first-match remote_mgmt_allow_policy
  class remote_access
    permit
interface vlan 1000
  ip address 10.20.17.21 255.255.248.0
  access-group input ALL
  service-policy input remote_mgmt_allow_policy
  no shutdown
How would I configure my speech server to isten on 554?
Thanks in advance
23 Replies 23
Borys Berlog
Hello Reginald
Currently you have only basic network configuration, there is no loadbalancing config
I'm not sure what exactly you're asking about , but basically you need to have
- real servers configured on ACE (
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA3_1_0/configuration/slb/guide/rsfarms.html#wp999495)
- serverfarm configured on ACE (
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA3_1_0/configuration/slb/guide/rsfarms.html#wp1014522)
- L7 policy map (
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA3_1_0/configuration/slb/guide/classlb.html#wp1171109 ,
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA3_1_0/configuration/slb/guide/classlb.html#wp1027248 )
- L4 policy map , class-map (
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA3_1_0/configuration/slb/guide/classlb.html#wp1027819)
And then apply it on necessary interface.
This is a general configuration, in your specific case you may need to configure some additinal features (e.g. I think you will need to have stickiness enabled
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA3_1_0/configuration/slb/guide/sticky.html but it depends on your application)
links are for old config guids , but basic is pretty much the same for all versions.
Please check them and try to narrow down your question a bit.
Cesar Roque
Level 4
Level 4
Here is a basic loadbalance configuration:
access-list Allow_Access line 10 extended permit ip any any
rserver host test
  ip address x.x.x.x  ==============change this for the real IP address of your servers
  inservice
rserver host test2
  ip address x.x.x.x
  inservice
serverfarm host LB
  rserver test2
    inservice
  rserver test
    inservice
class-map type management match-any NSS-ACCESS
  10 match protocol telnet any
  30 match protocol icmp any
  40 match protocol http any
  50 match protocol https any
class-map match-all VIP
  2 match virtual-address z.z.z.z tcp eq 554 ========change z.z.z.z for you real VIP address
policy-map type management first-match NSS_MGMT
  class NSS-ACCESS
    permit
policy-map type loadbalance first-match test
  class class-default
   serverfarm LB
policy-map multi-match clients
  class VIP
    loadbalance vip inservice
    loadbalance policy test
    loadbalance vip icmp-reply active
    nat dynamic 1 vlan 112
interface vlan 112
  ip address 10.198.16.91 255.255.255.192
  access-group input Allow_Access
  nat-pool 1 10.198.16.122 10.198.16.122 netmask 255.255.255.192 pat
  service-policy input NSS_MGMT
  service-policy input clients
  no shutdown
ip route 0.0.0.0 0.0.0.0 10.198.16.65
Cesar R
--------------------- Cesar R ANS Team
Thanks, I made notifications and this is the current config:
rserver host nss01
   ip address 10.2.4.70
   inservice
serverfarm host test_lab
   rserver nss01 554
class-map type rtsp loadbalance match-all L7SLBCLASS
   10  match rtsp url /10.2.4.70/synthesizer
How do I verify this config is functional?
Hi Reginald,
it should be like this:
rserver host nss01
   inservice
   rserver nss01 554
   10  match rtsp url  /synthesizer
  2 match virtual-address 10.2.4.70 tcp eq rtsp
policy-map type loadbalance first-match LB
  class L7SLBCLASS
   serverfarm test_lab
  class VIP
    loadbalance policy LB
This should work.
Cesar R
Hi Cesar, here's what I configured so far:
rserver host nss01
  ip address 10.20.17.70
  inservice
serverfarm host test_Lab
  rserver nss01 554
   class remote_access
   permit
policy-map type loadbalance rtsp first-match RTSP_L7_POLICY
   class L7SLBCLASS
I'm trying to configure the rest:
  class VIP
Thanks for your help
Reg
Hi Reginald,
the configuration looks good, just be sure to do inservice on the serverfarm
  rserver nss01 554
   inservice
Cesar R
Hi Cesar,
I'm a little confused with configuring the VIP
Error: VIP address is the same as an rserver IP in the context
What should be my reserver IP be and what should my VIP be?
Thanks.
Hello Reginald,
The IP address in the rservers is the real IP address of the server
The VIP address is the IP that your clients will use to access the application.
Cesar R
Hi Cesar,
I believe I have it now:
2 match virtual-address 10.2.4.21 tcp eq rtsp (this now appears in my running config)
What kind of valid test would you suggest?
Thanks for your help with this, it's much appreciated.
Reginald
Hi Reginald,
Just send RTSP traffic to the VIP address 10.2.4.21 and you should see the video
If does not work, please gather the output of the show conn command
Cesar R
It didn't work so here's the show running config  probe rtsp probe01  rserver host nss01   ip address 10.2.4.70   inservice  serverfarm host Nuance_Lab   rserver nss01 554   class-map type rtsp loadbalance match-all L7SLBCLASS   10 match rtsp url /synthesizer class-map match-all VIP   2 match virtual-address 10.2.4.21 tcp eq rtsp class-map type management match-any remote_access   2 match protocol xml-https any   3 match protocol icmp any   4 match protocol telnet any   5 match protocol ssh any   6 match protocol http any   7 match protocol https any   8 match protocol snmp any  policy-map type management first-match remote_mgmt_allow_policy   class remote_access     permit  policy-map type loadbalance rtsp first-match RTSP_L7_POLICY   class L7SLBCLASS  policy-map multi-match clients  interface vlan 1000   ip address 10.2.4.21 255.255.248.0   access-group input ALL   service-policy input remote_mgmt_allow_policy   no shutdown
Hi Reginald,
Please send me the running-config in a txt format
Cesar R
Sorry about that, here it is:
probe rtsp probe01
rserver host nss01
  inservice
  rserver nss01 554
  class remote_access
    permit
  class L7SLBCLASS
interface vlan 1000
  no shutdown
ip route 0.0.0.0 0.0.0.0 10.20.16.1
Hi Reginald,
The real server has this IP 10.2.4.70, right?
In the serverfarm we need to have the rserver inservice, like this:
  rserver nss01 554
    inservice========================add this
The VIP needs to an IP address available it should be in use only in the ACE class-map
interface vlan 1000
  no shutdown
You will have to change the IP address of VLAN1000 or the VIP address
In the policy-map type loadbalance you have to add the serverfarm:
  class L7SLBCLASS
    serverfarm Nuance_Lab=================add this
The policy-map multi-match should look like this:
  class VIP
   loadbalance policy RTSP_L7_POLICY
You need to add the policy to the interface, like this:
interface vlan 1000
  ip address 10.2.4.XX 255.255.248.0
  service-policy input clients=======================add this
  no shutdown
If this does not work, pleas gather the show conn output
Cesar R
