Configuring ACE 4710 for Load Balancing Speech servers
rdancy123
Hello, I'm configuring ACE 4710's for the first time and I want to load balance my Nuance speech servers on port 554. Here's my configuration on ACE01:
hostname ace471001
interface gigabitEthernet 1/1
  switchport access vlan 1000
  no shutdown
interface gigabitEthernet 1/2
  shutdown
interface gigabitEthernet 1/3
  shutdown
interface gigabitEthernet 1/4
  shutdown
access-list ALL line 8 extended permit ip any any
rserver host nss01
class-map type management match-any remote_access
  2 match protocol xml-https any
  3 match protocol icmp any
  4 match protocol telnet any
  5 match protocol ssh any
  6 match protocol http any
  7 match protocol https any
  8 match protocol snmp any
policy-map type management first-match remote_mgmt_allow_policy
  class remote_access
    permit
interface vlan 1000
  ip address 10.20.17.21 255.255.248.0
  access-group input ALL
  service-policy input remote_mgmt_allow_policy
  no shutdown
How would I configure my speech server to isten on 554?
Thanks in advance
23 Replies 23
Hi Cesar,
I made my changes except VIP, still a confused about it, sorry. My network admin gave my range of addresses to use in the 10.2.4.0 range. Should I use one that is available for VIP? Thanks in advance
probe rtsp probe01
rserver host nss01
  ip address 10.2.4.70
  inservice
serverfarm host Nuance_Lab
  rserver nss01 554
    inservice
class-map type rtsp loadbalance match-all L7SLBCLASS
  10 match rtsp url /synthesizer
class-map match-all VIP
  2 match virtual-address 10.2.4.21 tcp eq rtsp
  class remote_access
    permit
policy-map type loadbalance rtsp first-match RTSP_L7_POLICY
  class L7SLBCLASS
    serverfarm Nuance_Lab
policy-map multi-match clients
interface vlan 1000
  ip address 10.2.4.21 255.255.248.0
  service-policy input clients
  no shutdown
Hi Reginald,
Yes, for example
interface vlan 1000
  ip address 10.2.4.22 255.255.248.0
  no shutdown
Cesar R
ANS Team
--------------------- Cesar R ANS Team
Hi Cesar,
10.2.4.22 just so happens to be the IP of my other ACE 4710. This is what I have:
2 Cisco 3945 routers with Sip proxy
1 Cisco 3750-e catalyst switch
2 Cisco Ace 4710
2 NSS servers (plus CVP, UCCX, CUPS)
That said, I do have 10.2.4.23, available.
Thanks for your help, this is my first experience with Ace.
Hi Cesar,
I modified VIP so I think I'm good now:
probe rtsp probe01
rserver host nss01
  inservice
  rserver nss01 554
    inservice
  2 match virtual-address 10.2.4.23 tcp eq rtsp
  class remote_access
    permit
  class L7SLBCLASS
interface vlan 1000
  no shutdown
ip route 0.0.0.0 0.0.0.0 10.20.16.1
Thanks again for all your help!!
Reginald
Hi Reginald,
You will need to configure a nat-pool to avoid assymetric flows.  In addition you need to add this:
   class VIP
     loadbalance vip inservice
     loadbalance policy L7SLBCLASS
     nat dynamic 1 vlan 1000
interface vlan 1000
  nat-pool 1 10.2.4.23  10.2.4.23  netmask 255.255.248.0 pat ====add this line
  no shutdow
With this it should work properly.
Cesar R
ANS Team
Hey Cesar,
Thanks for your response, I made the changes. All that's left now to test it.
Once again I appreciate your help:
probe rtsp probe01
rserver host nss01
  inservice
  rserver nss01 554
    inservice
  class remote_access
    permit
  class L7SLBCLASS
  class VIP
interface vlan 1000
  no shutdown
Many thanks!
Reginald
Hi Reginald,
You still are missing the rest of the configuration in the policy-map multi-match.
It should look like this:
   class VIP
Cesar R
ANS Team
This should do it:
probe rtsp probe01
rserver host nss01
  inservice
  rserver nss01 554
    inservice
  class remote_access
    permit
  class L7SLBCLASS
  class VIP
    loadbalance policy RTSP_L7_POLICY
interface vlan 1000
  no shutdown
Reginald
Hi Reginald,
Yes, that configuration should work.
Cesar R
ANS Team
