04-15-2013 08:45 PM
Hi Guys,
I am going through some strange issue.There is one application hosted behind Cisco ACE 4710 and when application team try to access the application the connection gets dropped exactly after 5 minutes.But when they try to access the application directly through the server(bypassing the cisco ACE) the connection doesnot get dropped.The configuration is pretty straightforward,nothing fancy.if anyone has faced this similar issue before with Cisco ACE 4710 Please let me know.
probe tcp TCP_8101
port 8101
interval 10
faildetect 5
passdetect interval 40
open 1
class-map match-all app_ASPEN_DCT_PREProd_class
2 match virtual-address x.x.x.x tcp eq https
serverfarm host app_ASPEN_DCT_PREProd
probe TCP_8101
rserver servername1 8101
inservice
rserver servername2 8101
inservice
policy-map type loadbalance first-match app_ASPEN_DCT_PREProd_policy
class class-default
serverfarm app_ASPEN_DCT_PREProd
policy-map multi-match POLICY-LB-VLAN488
class app_ASPEN_DCT_PREProd_class
loadbalance vip inservice
loadbalance policy app_ASPEN_DCT_PREProd_policy
loadbalance vip icmp-reply active
nat dynamic 1 vlan 488
04-15-2013 10:29 PM
The default inactivity timeout are as
follows: TCP:3600sec UDP:120secs ICMP:2sec
These are inactivity timeouts, meaning if the connections are idle for these many seconsds then the connection will be dropped.
If you need a different TCP timeout value, you can change it using the follwoing example
To change TCP idle timeout to 5 minutes
parameter-map type connection TCP-PARAM
set timeout inactivity 300
class-map match-all TCP-CLASS
match port tcp any
policy-map multi-match VIP
class TCP-CLASS
connection advanced TCP-PARAM
Siva
04-16-2013 12:11 PM
Hi Siva,
As per the cisco document,
Starting with software version A4(1.0), the default connection inactivity timeout settings for the ACE have changed to the following values:
ICMP—2 seconds
TCP—3600 seconds (1 hour)
HTTP/SSL—300 seconds
UDP—10 seconds
How to increase the HTTP/SSL default timeout value of 300 Second to more ?? I tried to increase the timeout value for HTTP/SSL only,but ACE doesnot have any option
nuspthtestlds001/Admin(config-parammap-conn)# set timeout inactivity ?
<0-3217203> Inactivity (TCP 3600, HTTP/SSL 300, UDP 10, ICMP 2)
If i set value let's say 500 does it apply for all TCP,HTTP/SSL,UDP and ICMP.
Please suggest.
04-17-2013 11:22 AM
Hi Saroj,
If you are running 5.x then you also have a option to add the parameter map globally.
read section :
If you want to apply it for specific VIP then you should apply as follows:
parameter-map type connection connection_pm
set timeout inactivity 600
serverfarm host TEST_SERVERFARM
probe TCP-80-PROBE
rserver TEST 80
inservice
class-map match-all TEST_CM
2 match virtual-address 10.72.54.19 tcp eq 80
policy-map type loadbalance first-match TEST-PM
class class-default
serverfarm TEST_SERVERFARM
class TEST_CM
loadbalance policy TEST-PM
connection advanced-options connection_pm
Hope that helps.
regards,
Ajay Kumar
04-17-2013 08:11 PM
Hi Ajay,
Appreciated your quick response
Will it change HTTPS inactivity timeout too ??? or will this change TCP inactivity timeout. For my issue i need to change the HTTPS timeout inactivity timeout. Could you please suggest how to do that ??
04-18-2013 12:16 AM
Hi Saroj,
Before applying the parameter map :
ace30/Admin# sh parameter-map CONN
Parameter-map : CONN
Description : -
Type : connection
nagle : disabled
slow start : disabled
buffer-share size : 32768
inactivity timeout (seconds) : TCP: 3600, UDP: 10, ICMP: 2, HTTP/SSL: 300
reassembly timeout (seconds) : 60
embryonic timeout (seconds) : 5
ack-delay (milliseconds) : 200
WAN Optimization RTT (milliseconds): 65535
half-closed timeout (seconds) : 3600
fast FIN timeout (seconds) : disabled
TOS rewrite : disabled
syn retry count : 4
TCP MSS min : 0
TCP MSS max : 1460
tcp-options drop range : 0-0
tcp-options allow range : 0-0
tcp-options clear range : 1-255
selective-ack : clear
timestamp : clear
window-scale : clear
window-scale factor : 0
reserved-bits : allow
random-seq-num : enabled
SYN data : allow
full-proxy-mss-mismatch : disabled
exceed-mss : drop
urgent-flag : allow
conn-rate-limit : disabled
bandwidth-rate-limit : disabled
ace30/Admin#
After applying the parameter map :
ace30/Admin(config)# parameter-map type connection CONN
ace30/Admin(config-parammap-conn)# set timeout inactivity 600
ace30/Admin(config-parammap-conn)# end
ace30/Admin#
Description : -
Type : connection
nagle : disabled
inactivity timeout (seconds) : 600 <<< You will notice that the value has changed for all
syn retry count : 4
TCP MSS min : 0
TCP MSS max : 1460
timestamp : clear
SYN data : allow
exceed-mss : drop
urgent-flag : allow
So to answer your question the suggested changes will change timeout for HTTPS inactivity timeout also.
regards,
Ajay Kumar
07-02-2015 06:16 PM
Is there anyway to increase JUST the http/ssl portion.
What I would really want is to change:
to
inactivity timeout (seconds) : TCP: 3600, UDP: 10, ICMP: 2, HTTP/SSL: 1800
07-07-2015 02:17 AM
This is how you apply timeouts for http connections
policy-map multi-match HTTP
class HTTP
connection advanced-options HTTP
class-map match-any HTTP
2 match port tcp eq www
parameter-map type connection HTTP
set timeout inactivity 1200
Then apply this service-policy globally or in the interface from where the traffic is
coming in
