CSM: connect to console
mruuth
Hi all,
I have tried with my normal blue console cable , 9600 and hyperterminal. No success! Is the consoleport at CSM-blade something else?
Mats
use the console port of your pc but use an ethernet cable.
Gilles.
6 Replies 6
cprice2k7
Your best bet is to use the 6500 console port. The RJ-45 connector, which is covered by a removable plate, is used to connect a management station device or a test device. This connector is used by field engineers to perform testing and to obtain dump information.
I want to obtain dump information with commands I have been given from Gilles Dufour.
Mats
Gilles Dufour
Mats,
use a normal ethernet cable [pc to switch type of cable]
Gilles.
Gilles,
I'm sorry to bother you but do you mean that I shall connect the cable between csm consoleport and ethernetport on a PC? What application shall I use and how do I connect? Telnet to 127.0.0.50 port 23?. I tried to connect console and ethernetport on PC but no link up was the result. Tested with straight and crossed.
Mats
Gilles.
Yes,
Now its working.
Thanks a lot.
Mats
