CSS 11506 design issue
julxu
Just want get an advice:
Can a client/server application use CSS to encrypt the traffic?
server is a unix server and client can be unix and winPC, most of them are PC.
the client/server traffic is TCP. can I put CSS between client and server? and encrypt the traffic?
if so, how can I do it?
if not, is any other cisco box can achive this?
Any comments will be appreciated
Thanks in advance
Diego Vargas
Hi, well this is not a common design but the CSS ia able to encrypt clear text traffic by doing SSL Initiation, you would need to analyze if that configuration would work for you:
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/css11500series/v8.10/configuration/ssl/guide/initiate.html#wp1010308
Hope it helps!!
Diego Vargas
Hope it helps!!
