CSS Flow Statistics Description
ppatel
Community Member
When a flow statistics is performed in debug mode on a CSS what do the following fields actually mean
FM TCP Flows Timed Out 51
FM UDP Flows Timed Out 0
FP TCP Flows Timed Out 4304192
FP UDP Flows Timed Out 869078
It tells you how many times the CSS removed the flow because it had seen no
activity on it.
Any flow that remains inactive for the default/configured timeout value ( I think its 16sec for http)is timed out.
You can increase this timer by
using the "flow-timeout-multiplier " under the content rule. This parameter
is detailed here:
content yourcontent
add service yourservice1
add service yourservice2
vip address x.x.x.x
advanced-balance sticky-srcip
sticky-inact-timeout 600
flow-timeout-multiplier 5400
active
(The value to choose with flow-timeout-multiplier command should be in increments of 16 seconds.For eg the above value means one day (5400x16=86400secs).
Syed Iftekhar Ahmed
ppatel
Community Member
Hi Syed Iftekhar,
What does the FM TCP Flows Timed Out 51 exactly mean. Does it mean a flow is setup in the slow path and it is not pushed to the fast-path cache but still abides by the flow-timeout parameter?
Pravin
