CSS Script to search for a specific Keyword for keepalive
chetona
Hello
I am trying to figure out if this is possible. I want the CSS to check a web page for a specific word such as "ClientABC" any where in the page. If the word is found, then CSS will assume that page is working fine.
The reason for this is: we want to know if database does not send the output to the page, CSS should tell us that.
I found one script close to this but not sure if this will help me at all..
!no echo
! Filename: ap-kal-httptag
! Parameters: HostName WebPage HostTag
! Description:
! This script will connect to the remote host and do an HTTP
! GET method upon the web page that the user has asked for.
! This script also adds a host tag to the GET request.
! Failure Upon:
! 1. Not establishing a connection with the host.
! 2. Not receiving an HTTP status "200 OK"
if ${ARGS}[#] "NEQ" "3"
echo "Usage: ap-kal-httptag \’Hostname WebPage HostTag\’"
exit script 1
endbranch
! Defines:
set HostName "${ARGS}[1]"
set WebPage "${ARGS}[2]"
set HostTag "${ARGS}[3]"
! Connect to the remote Host
set EXIT_MSG "Connection Failure"
socket connect host ${HostName} port 80 tcp
! Send the GET request for the web page
set EXIT_MSG "Send: Failed"
socket send ${SOCKET} "GET ${WebPage} HTTP/1.0\nHost: ${HostTag}\n\n"
! Wait for a good status code
set EXIT_MSG "Waitfor: Failed"
socket waitfor ${SOCKET} "200 OK"
no set EXIT_MSG
socket disconnect ${SOCKET}
exit script 0
mmellet
Level 3
Level 3
I see no way to set that up in the docs. You could ask Cisco or at least put in an enhancement request.
nextgen.systems
Hi there !
I am not sure about the current status of your investigation but I believe there are a number of ways to do what you want by just using the http keepalives / get statement.
I think that what you really want to do is to monitor the database connection and for this you can create a test page (asp) that connects to the backend db and returns either a 'success' or 'failed'.
The page contents only change on failure causing the CSS to pull that webserver out of the cluster.
Leonel
