Extended Validation Certificate in Cisco SSL module
lukaszkhalil
Hello
Does anybody install the VeriSign Extended Validation certificate in the Cisco SSLM module?
I had some issues with it. Below I am attaching the VeriSign's knowledgebase regarding such installation on Apache server
https://knowledge.verisign.com/support/ssl-certificates-support/index?page=content&id=SO10890
I could not delete the rootCA cert, because of the chain incomplete issue.
Thank you in advance for any help.
Lukas
chrhiggi
Level 3
Level 3
Hello Lukas-
EV certs are supported on the SSLM for SSL decryption and initiation.  The client browser handles the extended functions of the EV certificates - The SSL server does not do anything it would not for a normal certificate, so the SSLM is unaware/transparent to the change.  You will want to check out bug ID CSCsl42088, depending on how you choose to deploy the trustpoint, you may need to have a minimum code to meet the fix for it.
For anyone who is interested, here is a good bit of information about what EV certs are:
http://en.wikipedia.org/wiki/Extended_Validation
Chris
