External DNS reference in ACE
Jack Dixon
Community Member
I have an External DNS: 12.53.18.186
I have IP (VIP😞 10.35.153.69
How to configure ACE to reference this external DNS IP? (what are comds, or better still, URL reference.)
Andrew Nam
Level 4
Level 4
Hi Jack
Can you give more info about why you need to configure ACE to reference this external DNS IP?
regards
Andrew
Andrew,
Sure; below is the basic ACE lb template the program manager handed off to me:
Complete Description of the Request: Implement Load Balancer on VLAN 401 in XYZ Dallas
App: Production Extranet Farm
Test/Prod: Production
IP (VIP): 10.35.153.69
DNS: bpnwww.mbco.com
Virtual Service Port: 80, 443, 4081
Real Server Name: mbsdalweb15, mbsdalweb23, mbsdalweb24, mbsdalweb25, mbsdalweb26, mbsdalweb27, mbsdalweb28
Real Server IP: 10.35.153.68, 10.35.153.55, 10.35.153.56, 10.35.153.57, 10.35.153.58, 10.35.153.59, 10.35.153.60,
Ports to be balanced: 80, 443, 4081
Load-Balancing Method: Least Connections
Persistence Method: Yes, timeout = 1260 seconds
Rules: None required.
Health Monitor: ICMP Ping to server
Thanks for any assist you can give,
jack
Hi Jack
As per the basic ACE lb template the program manager handed off to you, you don't need to configure ACE to reference this external DNS IP.
Generally speaking, this DNS name resolution happens between client and DNS server before the tc connection request sneds out to the ACE.
Step 1. DNS name resolution between client and DNS server
Step 2. Once the client understand this domain name "bpnwww.mbco.com" resolves to 10.35.153.69, the client will  initate tcp connection to the resolved IP (in this case vip address defined on ACE).
Step 3. TCP 3 ways shandshake happens between the client and ACE.
so on.
I hope this answers your question.
regards
Andrew
Andrew,
Ok, thanks much for research and reply.
Jack
