SMTP and IMAP ACE Probe configuration Example
bala020881
Could someone share he SMTPS and IMAPS probe setting configuration in CISCO ACE 4710 for my reference.
I have two server 10.1.1.58 and 10.1.1.59 which supposed to be load balaced for the service 993 and 465.
BR
pablo.nxh
Level 8
Level 8
Hello There,
The ACE has built-in scripted probes in order to check connectivity beyond layer 4 with these kinds of mail servers but only for the unencrypted versions SMTP/IMAP.
In your case since you're working with these protocols over SSL/TLS, you'll need to configure regular TCP probes for each serverfarm so reachability will be test'd based on TCP port.
probe tcp IMAPS-993
  port 993
  interval 5
  faildetect 2
  passdetect interval 3
  passdetect count 1
  open 1
probe tcp SMTPS-464
  port 465
  interval 5
  faildetect 2
  passdetect count 1
  open 1
__ __
Pablo
