High Connections within Ace 4710
Don Brack
Is this normal to have millions of current connections within an ace 4710? There is only 3 current connections but shows a high number?
Thanks!!
ajayku2
It does not look normal. You should raise a TAC case and work on it.
TAC is claiming a bug.
Reference  hitting bug ID: CSCtq39716
yeah now it make sense. It is more of snmp polling issue.
