how could I define fault-redundancy (ft) for a context?
blankguy7
I'm opening a new one message and close the other..
So, how could I define redundancy on a context?
I've two ACE with 1 Admin context and 1 PROD context, ft config follows.
I could not configure track-interface or query-interface for vlan in a other context :
ACE3/Admin(config-ft-track-intf)# track-interface vlan 20
Error: vlan '20' does not exist!
the ft for the admin context is running well (1 out and 1 in) but not for the PROD context (both in) see at the end :
ACE3 config
ft interface vlan 1000
  ip address 10.1.1.1 255.255.255.0
  peer ip address 10.1.1.2 255.255.255.0
  no shutdown
ft peer 1
  heartbeat interval 300
  heartbeat count 10
  ft-interface vlan 1000
  query-interface vlan 10
ft group 1
  peer 1
  priority 150
  associate-context Admin
ip route 0.0.0.0 0.0.0.0 192.168.10.1
context PROD
  allocate-interface vlan 20
  allocate-interface vlan 30
ft group 2
  peer 1
  priority 150
  associate-context PROD
  inservice
ACE4 config
  peer ip address 10.1.1.1 255.255.255.0
  no shutdown
ft peer 1
  heartbeat count 10
ft group 1
  peer 1
  peer priority 150
  inservice
context PROD
ft group 2
  peer 1
  peer priority 150
  inservice
ACE3/Admin# sh ft group det
FT Group                     : 1
No. of Contexts              : 1
Context Name                 : Admin
Context Id                   : 0
Configured Status            : out-of-service
Maintenance mode             : MAINT_MODE_OFF
My State                     : FSM_FT_STATE_INIT
My Config Priority           : 150
My Net Priority              : 150
My Preempt                   : Enabled
Peer State                   : FSM_FT_STATE_ACTIVE
Peer Config Priority         : 100
Peer Net Priority            : 100
Peer Preempt                 : Enabled
Peer Id                      : 1
Last State Change time       : Thu May 31 16:01:54 2012
Running cfg sync enabled     : Enabled
Running cfg sync status      :
Startup cfg sync enabled     : Enabled
Startup cfg sync status      :
Connection sync enabled      : Enabled
Bulk sync done for ARP       : 0
Bulk sync done for  LB       : 0
Bulk sync done for ICM       : 0
Bulk sync done for  ND       : 0
FT Group                     : 2
No. of Contexts              : 1
Context Name                 : PROD
Context Id                   : 1
Configured Status            : in-service
My State                     : FSM_FT_STATE_ACTIVE
Peer State                   : FSM_FT_STATE_STANDBY_HOT
Peer Id                      : 1
Running cfg sync status      : Running configuration sync has completed
Startup cfg sync status      : Startup configuration sync has completed
ACE4/Admin# sh ft group detail
FT Group                     : 1
No. of Contexts              : 1
Context Id                   : 0
My Config Priority           : 100
My Net Priority              : 100
Peer State                   : FSM_FT_STATE_UNKNOWN
Peer Config Priority         : Unknown
Peer Net Priority            : Unknown
Peer Preempt                 : Unknown
Peer Id                      : 1
Last State Change time       : Thu May 31 15:41:39 2012
FT Group                     : 2
No. of Contexts              : 1
Context Name                 : PROD
Context Id                   : 1
My State                     : FSM_FT_STATE_STANDBY_HOT
Peer Config Priority         : 150
Peer Net Priority            : 150
Peer Id                      : 1
Last State Change time       : Fri Jun  1 14:02:55 2012
ACE4/Admin#
Thanks in advance,
Best regards,
jm
Run the command and check
ACE_5/Admin# show ft group detail           FT Group                     : 1 No. of Contexts              : 1 Configured Status            : in-service Maintenance mode             : MAINT_MODE_OFF My State                     : FSM_FT_STATE_ACTIVE  << The context on this device is active >> My Config Priority           : 110 My Net Priority              : 110 My Preempt                   : Enabled Peer State                   : FSM_FT_STATE_STANDBY << Peer device is standby >> Peer Config Priority         : 100 Peer Net Priority            : 100 Peer Preempt                 : Enabled Peer Id                      : 1 Last State Change time       : Thu Apr  2 00:00:00 2009 Running cfg sync enabled     : Enabled Running cfg sync status      : Running configuration sync has completed Startup cfg sync enabled     : Enabled Startup cfg sync status      : Running configuration sync has completed Bulk sync done for ARP: 0 Bulk sync done for LB: 0 Bulk sync done for ICM: 0
Use this command to check if hearbit is passing or not:
ACE_5/Admin# show ft stats
HA Heartbeat Statistics
Number of Heartbeats Sent                 : 20
Number of Heartbeats Received             : 20
Number of Heartbeats Missed               : 0
Number of Unidirectional HB's Received    : 0
Number of HB Timeout Mismatches           : 0
Num of Peer Up Events Sent                : 0
Num of Peer Down Events Sent              : 0
Successive HB's miss Intervals counter    : 0
Successive Uni HB's recv counter          : 0
10 Replies 10
sivaksiv
Both context should be inservice on both boxes for ft to work.
for ft tracking do you have th vlan 20 configured in that context?
Siva
Cesar Roque
Level 4
Level 4
Hi JM,
I think that the problem is because you are trying to configure FT tracking using a VLAN that does not exists on the Admin Context:
FT Tracking needs to be configured on each Context, this is the only FT configuration that you have to do in the  Context itself
The rest of the FT configuration is done in the Admin Context.
So if you want to track Vlan20 for the PROD Context, just changeto the Context and apply the configuration.
Cesar R
--------------------- Cesar R ANS Team
Hi Cesar,
Thanks for your answers!
I knew that it is not possible to define FT tracking VLAN that belongs to a another Context.
But I had not thoughts to configure this FT tracking VLAN in my context.
Now, I've configured the FT tracking on context and It's running well. Thanks a lot
Last question: with the command show ft track detail I saw always Status : in-service.
How to know with FT aktiv ist?
Best regards,
jm
Hi JM,
I did not understand your question, could you please elaborate a bit more.
Hi Cesar,
I'd like to known how to see if my "fault-redundancy" is running?
Which command to use it to check-up that?
How to see which ACE is activ and which is STANDBY?
So, that was my question! Because the command show me that all ft are in-service but not ACTIVE or STANDBY.
Thanks and best regards,
Jerome
You can use the show ft group detail on each Context and that output will give you all the information. Including Active and Standby state.
Cesar R
fb_webuser
Level 6
Level 6
its easy to say but difficult to do on the field..........
Posted by WebUser Sajadur Sajed from Cisco Support Community App
All thing could be explain... I don't understood what's you mean?
Thanks for your help and answers!
It was really helpfull,
Best regards,
jm
