How do you view the system image location for WAVE device?
adil.nasser3
All,
I am trying to confirm the location of where the system image resides on a WAVE-294?  I performed the command, " dir" and I only see other files and directories.  Where is the system image hiding?  What command can I use to confirm its location?  It is running Version oe204-4.4.5.5 but unable to find the location of the .bin file?
waascm01#dir
      size          time of last change             name
        125052  Wed Jan 15 15:53:00 2014           UcliEvt.bak
         21052  Thu Jan 16 09:23:00 2014           UcliEvt.log
          4096  Mon Nov 26 20:28:27 2012  <DIR>    actona
        954263  Sat Mar 16 06:12:18 2013           cms-db-03-16-2013-10-06_4.4.5
.0.5.dump
        825792  Thu Mar 21 14:29:03 2013           cms-db-03-21-2013-14:29:03:65
5.txt
          4096  Mon Nov 26 20:55:18 2012  <DIR>    core_dir
          4096  Mon Nov 26 20:56:21 2012  <DIR>    crash
             0  Tue Mar  5 04:23:30 2013           db-downgrade.log
          4096  Mon Mar 25 12:05:30 2013  <DIR>    downgrade
           756  Tue Mar  5 12:32:23 2013           emerg-db-03-05-2013-17-32.txt
          4096  Fri Dec 27 20:10:00 2013  <DIR>    errorlog
           405  Thu Jun 13 15:03:26 2013           irqbal_debug.txt
          4096  Thu Jun 13 15:03:25 2013  <DIR>    logs
         16384  Mon Nov 26 20:24:58 2012  <DIR>    lost+found
          4096  Mon Nov 26 20:55:16 2012  <DIR>    pki
          4096  Thu Jan 16 00:02:00 2014  <DIR>    sa
         20480  Thu Jan 16 09:26:12 2014  <DIR>    service_logs
          4096  Thu Jun 13 15:03:30 2013  <DIR>    spool
       1946016  Thu Jan 16 09:25:52 2014           syslog.txt
             8  Thu Jan 16 09:00:50 2014           userdeletiontimestamp
          4096  Mon Nov 26 20:55:14 2012  <DIR>    var
          4096  Mon Nov 26 20:25:40 2012  <DIR>    vbs
           508  Mon Nov 26 20:55:15 2012           wdd.sh.signed
csebala_r1
System image will be loaded in the flash. You can verify the image version by type "sh flash".
