01-16-2014 06:35 AM
All,
I am trying to confirm the location of where the system image resides on a WAVE-294? I performed the command, " dir" and I only see other files and directories. Where is the system image hiding? What command can I use to confirm its location? It is running Version oe204-4.4.5.5 but unable to find the location of the .bin file?
waascm01#dir
size time of last change name
125052 Wed Jan 15 15:53:00 2014 UcliEvt.bak
21052 Thu Jan 16 09:23:00 2014 UcliEvt.log
4096 Mon Nov 26 20:28:27 2012 <DIR> actona
954263 Sat Mar 16 06:12:18 2013 cms-db-03-16-2013-10-06_4.4.5
.0.5.dump
825792 Thu Mar 21 14:29:03 2013 cms-db-03-21-2013-14:29:03:65
5.txt
4096 Mon Nov 26 20:55:18 2012 <DIR> core_dir
4096 Mon Nov 26 20:56:21 2012 <DIR> crash
0 Tue Mar 5 04:23:30 2013 db-downgrade.log
4096 Mon Mar 25 12:05:30 2013 <DIR> downgrade
756 Tue Mar 5 12:32:23 2013 emerg-db-03-05-2013-17-32.txt
4096 Fri Dec 27 20:10:00 2013 <DIR> errorlog
405 Thu Jun 13 15:03:26 2013 irqbal_debug.txt
4096 Thu Jun 13 15:03:25 2013 <DIR> logs
16384 Mon Nov 26 20:24:58 2012 <DIR> lost+found
4096 Mon Nov 26 20:55:16 2012 <DIR> pki
4096 Thu Jan 16 00:02:00 2014 <DIR> sa
20480 Thu Jan 16 09:26:12 2014 <DIR> service_logs
4096 Thu Jun 13 15:03:30 2013 <DIR> spool
1946016 Thu Jan 16 09:25:52 2014 syslog.txt
8 Thu Jan 16 09:00:50 2014 userdeletiontimestamp
4096 Mon Nov 26 20:55:14 2012 <DIR> var
4096 Mon Nov 26 20:25:40 2012 <DIR> vbs
508 Mon Nov 26 20:55:15 2012 wdd.sh.signed
01-21-2014 04:35 AM
System image will be loaded in the flash. You can verify the image version by type "sh flash".
