Bookmark
Subscribe
2246
How to block port and ip Router 2900
I'm trying to block Spotify in mi company. I can block the HTTP but https is steel working, so I need to block this with the port and ip, what it's the command to get this?
9 Replies 9
if you use proxy, then perhaps you can block this application there
Rikshit
Hello, Rikshit.
I don't have a proxy, I try to block this in the router per command line
try this
class-map match-any MUSIC_SITES
match protocol secure-http
or you can match based on contents of url, this will block both http and https
match protocol http url "*spotify*"
policy-map M_SITES
class MUSIC_SITES
drop
service-policy out (INTERNET INTERFACE)
I try with this command but HTTPS still working.
Proxy and Firewall are the only solutions as far as I know..The above commands were available in Internet and even I was not sure if they will work. Sorry..
Rikshit
Ok, Thankss rikshit.
so only with server proxy.
What proxy recommend you ? Squid + Squidguard?
Perhaps you can doing "nslookup www.spotify.com" and then block the IP adresses using an ACL.
Check this link :
http://www.techrepublic.com/article/block-access-to-a-web-site-using-the...
We use Sophos proxy . I don't know about squid
Rikshit
Check this link :
http://www.techrepublic.com/article/block-access-to-a-web-site-using-the-cisco-ios/
Rikshit
