How to check if waas is accerlating
mahesh18
Level 6
Level 6
hi all,
this waas is conencted to network but seems not in production
is there any command i can verify if it is passingtraffic or not?
also is there any command to tell is this is edge waas?
thanks
mahesh
Well, is it possible for you to attach show run from this unit? You can repalce the actual ip addresses wit hdummy ip addresses.
Regards.
10 Replies 10
Bhavin Yadav
Hi Mahesh,
here are few CLI commands to verify if WAAS is doing its job.
1. sh stat conn - List of all pass thru and optimized connections with details of optimization.
2. sh stat accelerator - check the status of the accelerator to see if it is doing it's job.
3. sh accelerator - Check to see which accelerators are enabled.
4. sh license - to verify if you tave transport / enterprise / video licenses.
5. sh alarm - to see if there is anything to worry about.
Above commands are true for WAAS 4.1.x, 4.2.x and 4.3.x versions. if you are using 4.0.x, the commands might be slightly different.
You wll find version dependent CLI command guides here:
http://www.cisco.com/en/US/products/ps6870/prod_command_reference_list.html
Hope this helps.
Regards.
PS: Please mark this Answered, if this answers your question.
Hi bhavin
Thanks for reply
sh license
License Name   Status      Activation Date Activated By
Transport      not active
Enterprise     active      11/21/2010      setAtUpgrade
Video          not active
here it shows only enterprise what does it mean ?
sh accelerator
Accelerator     Licensed        Config State    Operational State
cifs            Yes             Disabled        Shutdown
epm             Yes             Enabled         Running
http            Yes             Enabled         Running
mapi            Yes             Enabled         Running
nfs             Yes             Enabled         Running
ssl             Yes             Enabled         Running
video           No              Enabled         Shutdown
wafs-core       Yes             Disabled        Shutdown
wafs-edge       Yes             Enabled         Running
sh stat conn
Current Active Optimized Flows:                      0
   Current Active Optimized TCP Plus Flows:          0
   Current Active Optimized TCP Only Flows:          0
   Current Active Optimized TCP Preposition Flows:   0
Current Active Auto-Discovery Flows:                 0
Current Reserved Flows:                              40 **********************************what is  current reserver flow mean?C
urrent Active Pass-Through Flows:                   0
Historical Flows:                                    0
it does not show it is working
Hi Mahesh,
Yes, WAE is not optimizing traffic it seems.
Can you paste following CLI command from WAE?
sh wccp routers
sh egress method
sh run (you can put in the dummy ip address replacing original ip add)
Further, it also looks like you are using Legacy (OLD) CIFS optimization. We have to turn off old CIFS and turn on new CIFS AO which is disabled.
Please follow the information in this white paper:http://www.cisco.com/en/US/prod/collateral/contnetw/ps5680/ps6870/white_paper_c11-508426.html
Enterprise license means, you can use HTTP,CIFS, NFS, MAPI, EPM accelerators to optimize those individual traffic.
Regards.
sh egress-methods
Intercept method : WCCP
  TCP Promiscuous 61 :
      WCCP negotiated return method : negotiation is pending
                        Egress Method      Egress Method
      Destination        Configured            Used
      any          IP Forwarding           IP Forwarding
  TCP Promiscuous 62 :
Intercept method : Generic L2
      any          not configurable        IP Forwarding
#sh wccp  routers
This command is only available when running WCCP version 2
here is required info
Hmmm. Looks like WCCP is not working. not sure what hardware you are using on router / switching side ? Are you ising inline mode?
Regards.
Thanks for reply.
how can i check if it is inline mode?
Regards.
Hi bhavin
many thanks for the help.
for  some reasons i can not put config here.
In that case, I would suggest you to open a TAC case or involve your Cisco Sales engineer to help you with this deployment.
For your help, all the documentation is listed here:
http://www.cisco.com/en/US/products/ps6870/tsd_products_support_series_home.html
You probably want to go thru the Traffic interception topic to understand your deployment.
http://www.cisco.com/en/US/docs/app_ntwk_services/waas/waas/v431/configuration/guide/traffic.html
Hope this helps.
Regards.
BTW, looking at your config, this is Edge Waas. But in new CIFS AO, it WAE assumes role dynamically for edge and core.
Regards.
