How to make Load-balancing for UDP-requests?
wagnerch
I want to request a DNS-resolution from a client over a CSS11050-service (VIP-address) to a DNS-Server-farm.
I use a CSS11050 and it seems that there happens no PAT for UDP-packets.
When I send a nslookup to the VIP-address the packet is translated to the server address but not the return packet from the server. The real name-server address is sent back to my client.
Any suggestions what is wrong? The same configuration works fine for TCP-services.
Chris
j-block
Level 4
Level 4
Maybe you'll have to use a local hosts file. Check for bugs on your code version. I would think UDP packets should port-translate normally.
