How to pass original Client IP to load balanced IIS servers
pmajumder
Level 3
Level 3
Hi All,
I have a pair of CSS 11500 content services switches fronting our IIS web servers farm. On these IIS servers the IIS logs are enabled for our websites. However, when I analyze the IIS logs the client IP is always the IP address of the load balancer, and not the real client IP.
Can anyone help me configure the content switch to send the real IP, or is there some other method which will allow IIS to log the real client IP?
Any advice/pointers would be much appreciated.
Pradeep
2 Accepted Solutions
Before changing the equipment, you should check if you have any "group" in your config.
If your servers are using the CSS as default gateway, those groups could be safely removed and the CSS will stop changing the client ip address.
Gilles.
If you really have no group command with "add destination service" then the client traffic will go to the server with the client ip as the source. The service won't get any other traffic with the css address except for the keepalive
keepalive Agents1-Prodkeepalive
  type http
  port 80
  method get
  ip address y.y.y.y
  uri "/CSservice/KeepAlive.html"
  retryperiod 20
  maxfailure 1
  frequency 60
  active
this keepalive request will get to the server with the circuit ip of the CSS as the source.
9 Replies 9
litrenta
Level 3
Level 3
This is most likely due to having source groups with add destination services configured (each service in each content rule is added to a source group as add destination service). This is done when the topology is such that the server's default gateway is not the CSS and/or the server's return traffic does not pass back through the CSS to be natted.  A source group with the services added as destination services will nat the client's source IP to the group's VIP when that service is selected from a LB decision; this forces the server's response to pass through the CSS.  So, the topology needs to be re-examined if you require the client's source IP to be maintained.  The server's response must go through the CSS either by setting the server's default gateway as the CSS or using PBR on a Cat switch.
On the ACE we have the ability to insert an http header such as x-forwarded-for with the client ip then with an isapi filter on the IIS server you can log client ip's rather than the source ip.
Thanks for the response. We do have all our servers configured to use the CSS as their default gateway. I also have the services defined for each server 93 total) and then I have added those three services to my content rule.
You mention the ACE and the ability "to insert an http header such as x-forwarded-for with the client ip then with an isapi filter on the IIS server". Could you please elaborate and let me know where I can obtain those tools/filter?
Thanks Again,
Pradeep
HI There,
Just as a side note, you will also need a parameter map to insert the ip in every packet, otherwise you get the server guys moaning that the forwarding aint working
Gilles.
If the servers use the css as default gateway , nake sure you don't have a group with "add destination service" for the services involved in this load balance flow. Then the CSS will deliver the traffic to the server with the client ip as the source address.
code example for the filter (which will compile with visual studio) can be found at
http://blogs.msdn.com/b/david.wang/archive/2005/09/28/howto-isapi-filter-which-logs-original-client-ip-for-load-balanced-iis-servers.aspx
You can find an IIS7 plug in at
http://blogs.iis.net/anilr/archive/2009/03/03/client-ip-not-logged-on-content-server-when-using-arr.aspx
google isapi x-forwarded  it is a very popular topic.
Thank you both for the suggestions. I do not have any group command related to these three servers. What I have are one service rule for the sorry server, 3 Service rules, 3 keepalive rules and then the content rule as follows:
service Agents-ProdSorry
  ip address z.z.z.z
  port 80
  protocol tcp
  redundant-index 72
  active
  type http
  port 80
  method get
  ip address y.y.y.y
  retryperiod 20
  maxfailure 1
  frequency 60
  active
service Agents1-Prod
  ip address y.y.y.y
  protocol tcp
  keepalive type named Agents1-Prodkeepalive
  redundant-index 49
  active
content Agents-Prod
    vip address x.x.x.x
    protocol tcp
    port 80
    balance weightedrr
    add service Agents1-Prod
    add service Agents2-Prod
    add service Agents3-Prod
    primarySorryServer Agents-ProdSorry
    redundant-index 64
    advanced-balance sticky-srcip
    sticky-inact-timeout 20
    active
Clearly it sounds like it should work, but I must be doing something else incorrectly.
Pradeep
  type http
  port 80
  method get
  ip address y.y.y.y
  retryperiod 20
  maxfailure 1
  frequency 60
  active
That was it. I was just looking at the keepalive requests in the log and assumed everything else would alos have the CSS's address. It is keeping up the real client IP.
Thank you very much for the knowledge and the pointer.
Pradeep
etrade.admin
I am facing the same problem.
Could you please help me too...
I have a webserver configured on the content switch & now when I check the IIS logs, all the IP addresses are of the content switch instead of the client machines.
I am attaching my configure for you to review
CSS-GLOBAL# sh runn
!Generated on 10/26/2010 23:14:04
!Active version: sg0810106
configure
!*************************** GLOBAL ***************************
  dns primary 172.21.1.13
  dns secondary 192.168.0.50
  ssl associate rsakey eglobal eglobal.pem
  ssl associate cert eglobal-selfsigned eglobal.selfsigned.pem
  ssl associate rsakey glopedia glopedia.pem
  ssl associate cert glopedia glopedia.selfsigned.pem
  ssl associate cert eglobal-versign e-global-verisign.pem
  ssl associate cert glopedia-verisign glopedia-verisign.pem
  ssl associate cert EGlobal-Web EGlobal-Web.pem
  ssl associate cert EGlobal-Web-Chain EGlobal-Web.pem
  ssl associate cert Glopedia-Web-Chain Glopedia-Web.pem
  ftp-record conf 172.16.143.43 shahim des-password 1bnc2hnduhmgjend /
  ip route 0.0.0.0 0.0.0.0 172.21.21.1 1
  ip route 172.21.1.0 255.255.255.0 172.21.21.4 1
  ip route 172.16.0.0 255.255.0.0 172.21.21.4 1
  ip route 192.168.0.0 255.255.255.0 172.21.21.4 1
!************************* INTERFACE *************************
interface e1
  description "To Global Switch Foundary"
!************************** CIRCUIT **************************
circuit VLAN1
  ip address 172.21.21.49 255.255.255.0
!*********************** SSL PROXY LIST ***********************
ssl-proxy-list SSL-Proxy-List
  ssl-server 51
  ssl-server 51 rsakey eglobal
  ssl-server 51 vip address 172.21.21.51
  ssl-server 51 cipher rsa-with-rc4-128-md5 172.21.21.51 80 weight 10
  ssl-server 51 cipher rsa-with-rc4-128-sha 172.21.21.51 80 weight 8
  ssl-server 51 cipher rsa-export-with-rc4-40-md5 172.21.21.51 80 weight 5
  ssl-server 50
  ssl-server 50 rsakey glopedia
  ssl-server 50 vip address 172.21.21.50
  ssl-server 50 cipher rsa-with-rc4-128-md5 172.21.21.50 80 weight 10
  ssl-server 50 cipher rsa-with-rc4-128-sha 172.21.21.50 80 weight 8
  ssl-server 50 cipher rsa-export-with-rc4-40-md5 172.21.21.50 80 weight 5
  ssl-server 50 urlrewrite 1 *
  ssl-server 51 urlrewrite 1 *
  ssl-server 51 rsacert EGlobal-Web-Chain
  ssl-server 50 rsacert Glopedia-Web-Chain
  active
!************************** SERVICE **************************
service E-Global-https
  ip address 172.21.21.32
  port 80
  protocol tcp
  active
service Ghalia
  port 81
  protocol tcp
  ip address 172.21.21.31
  active
service GlobalInv
  port 80
  protocol tcp
  active
service dms
  ip address 172.21.1.115
  port 80
  protocol tcp
  keepalive type http
  active
service eglobal-http
  port 80
  protocol tcp
  keepalive type http
  active
service email
  ip address 172.21.1.122
  port 80
  protocol tcp
  keepalive type http
  active
service email123
  ip address 172.21.1.123
  port 80
  protocol tcp
  keepalive type http
  active
service glopedia
  ip address 192.168.2.32
  port 80
  protocol tcp
  active
service glopedia-expapps
  port 4028
  protocol tcp
  active
service secure-transfer
  type redirect
  no prepend-http
  keepalive type none
  domain https://www.e-global.com.kw
  active
service ssl-eglobal
  type ssl-accel
  keepalive type none
  slot 2
  add ssl-proxy-list SSL-Proxy-List
  active
service workflow
  ip address 172.21.21.44
  port 80
  protocol tcp
  keepalive type http
  active
!*************************** OWNER ***************************
owner EGlobal
  content eglobal-http
    no persistent
    protocol tcp
    port 80
    url "/*"
    add service eglobal-http
    active
  content eglobal-https
    protocol tcp
    port 443
    add service ssl-eglobal
    active
owner GhaliaWebSite
  content Ghalia-http
    vip address 172.21.21.53
    add service Ghalia
    protocol tcp
    port 80
    active
owner GlobalWebSite
  content GlobalInv-http
    vip address 172.21.21.52
    add service GlobalInv
    port 80
    protocol tcp
    active
owner Glopedia
  content bpmweb
    url "/workflow"
    protocol tcp
    port 80
    redirect "/bpmweb"
    active
  content cyberdocs
    add service dms
    protocol tcp
    port 80
    url "/CyberDocs*"
    active
  content dms
    url "/dms*"
    redirect "/CyberDocs"
    protocol tcp
    port 80
    active
  content email
    no persistent
    url "/email"
    protocol tcp
    port 80
    redirect "/owa"
    active
  content glopedia-expapps
    add service glopedia-expapps
    no persistent
    port 4028
    protocol tcp
    active
  content glopedia-http
    no persistent
    protocol tcp
    port 80
    url "/*"
    active
  content glopedia-https
    protocol tcp
    port 443
    active
  content owa
    add service email123
    protocol tcp
    port 80
    url "/owa*"
    active
  content workflow
    add service workflow
    no persistent
    protocol tcp
    port 80
    url "/bpmweb*"
    active
!*************************** GROUP ***************************
group Ghalia
  add destination service Ghalia
  active
group GlobalInv
  add destination service GlobalInv
  active
group dms
  add destination service dms
  add destination service email
  add destination service workflow
  add destination service glopedia
  add destination service email123
  add destination service glopedia-expapps
  active
group eglobal
  add destination service eglobal-http
  active
