L2TP tunnel with ACE
Ahmed Shahzad
L2TPV3 tunnels passing through ACE does not work. Traffic is passing in one direction but not in other direction, however L2TP tunnel is up and showing packet in but not out. L2TP tunnel configuration is as under:
pseudowire-class ether-pw
encapsulation l2tpv3
protocol none
ip local interface Loopback0
ip dfbit set
interface FastEthernet2/1.480
encapsulation dot1Q 480
no ip directed-broadcast
xconnect 10.173.32.62 480 encapsulation l2tpv3 manual pw-class ether-pw
l2tp id 480 480
l2tp cookie local 8 0 0
l2tp cookie remote 8 0 0
Shahzad.
Gilles Dufour
Is ace interface configured in bridge mode ? Did you try with normalization turned off ?
Do you have a sniffer trace of the traffic going in and out of ACE ?
Gilles.
Thanks Gilles for your reply.
ACE are configured in Routed Mode. I did not turned off the normalization, could be please reply with its configuration. Any other suggestion.
Shahzad.
L2TPv3 encapsulate data directly over IP (IP protocol number 115), not using UDP or TCP, do you think normalization would affect such traffic?
