LocalDirector & IE 6 Frameset/Style Sheet problems?
johnson.john
We are using the LD 417 to load balance across Sun webservers running Oracle Apache. We have just seen a problem where IE 6.x, accessed through the LDs, will not apply style sheets in Framesets, unless the page is refreshed, either by the user or programmatically. This does NOT happen to Netscape 7.x through the LDs or to IE 6.x when accessing the webservers directly.
Has anyone seen a problem similar to this and, if so, is there something in the LD to mitigate this problem?
owillins
Level 6
Level 6
I have also seen some issues with IE 6.0 with regard to the sticky cookies. It worked fine with IE 5.0
In your case have you tried IE5.0 and checking if it works. It usually is a browser issue.
