Question about Sticky in ACE4710
Hi everyone,
I have a issue with a sticky method in ACE loadbalancer.
The ACE receives incoming connections which it sees as a single IP (proxy) and we have the following configuration:
rserver host BCHAPP140
  ip address 10.20.36.30
  inservice
serverfarm host FWORK_8011
  failaction purge
  predictor leastconns
  probe PruebaHTTP
  rserver BCHAPP140 8011
    inservice
  rserver BCHAPP140 8211
    inservice
  rserver BCHAPP140 8311
    inservice
  rserver BCHAPP141 8011
    inservice
  rserver BCHAPP141 8211
    inservice
  rserver BCHAPP141 8311
    inservice
sticky ip-netmask 255.255.255.255 address source FWORK_8011_stickyIP
  replicate sticky
  serverfarm FWORK_8011
class-map match-all VIP_FWORK_8011
  description FRAMEWORK_8011
  2 match virtual-address 152.139.82.119 tcp eq 8011
policy-map type loadbalance first-match LB_POLICY_8011
  class class-default
    sticky-serverfarm FWORK_8011_stickyIP
policy-map multi-match POLICY-FWORK
  class VIP_FWORK_8011
    loadbalance vip inservice
    loadbalance policy LB_POLICY_8011
    loadbalance vip icmp-reply active
The problem we're seeing is that when it generate a lot of incoming connections, the balancer does not perform the load balance correctly, but sends most of the connections to a single server, for example: rserver BCHAPP140 8211.
We believe that the problem may be in the Source Sticky IP settings ... and we are considering making the change to sticky http-cookie.
I hope you can help me and explain how I could generate a correct configuration.
Thanks.
Roman Rodichev
Level 7
Level 7
Hi Jaime,
is this what you are looking for?
sticky http-cookie Cookie1 StickyGroup1
  cookie insert
  replicate sticky (if you have dual ACEs)
  class class-default
    sticky-serverfarm StickyGroup1
Roman
Hi.
Don't forget the cookie insert browser-expire flag to send a cookie just for the session in the browser.
