Redundancy and Load-balancing using one interface
cocolema
Community Member
Is it possible to both perform load-balancing and redundancy using one interface? I have the load-balancing portion working, but the redundancy portion is failing.
Cosby Coleman
TCCSI
Gilles Dufour
could you provide us more information on what is the topology, what you did and what is not working.
Gilles.
This is our current network diagram and it works.
outside
[router]
| dmz (10.10.10.x/24)
[ pix ]-----------------------[L2switch]-----[L2switch]
[router] [CSS] | | | |
| [wWW1] | [WWW2] |
| [APP1] [APP2]
inside
PIX: 10.10.10.1
CSS: 10.10.10.3
WWW VIP: 10.10.10.30
WWW1: 10.10.10.31
WWW2: 10.10.10.32
App VIP: 10.10.10.36
APP1: 10.10.10.37
APP2: 10.10.10.38
This is what we would like to achieve, with CSS1 being the master and CSS being redundant.
outside
[router]
| dmz (10.10.10.x/24)
|10.10.10.1 | | | | | |
[router] [CSS1] | | [CSS2] | |
| [wWW1] | [WWW2] [APP2]
| [APP1]
inside
This is our current config, which is also working just fine.
!Generated on 07/12/2002 13:57:59
!*************************** GLOBAL ***************************
bridge priority 65535
ip redundancy
app session 21.1.1.1
app
ip route 0.0.0.0 0.0.0.0 10.10.10.1 1
!************************* INTERFACE *************************
interface e7
bridge vlan 2
interface e9
bridge vlan 2
!************************** CIRCUIT **************************
circuit VLAN1
ip address 21.1.1.2 255.255.255.0
redundancy-protocol
circuit VLAN2
redundancy
ip address 10.10.10.3 255.255.255.0
!************************** SERVICE **************************
service DownstreamSwitch
ip address 10.10.10.16
type redundancy-up
active
service dummy
ip address 10.10.10.100
keepalive type none
active
service pcuservice1
ip address 10.10.10.37
keepalive type tcp
keepalive frequency 15
keepalive retryperiod 60
active
service pcuservice2
ip address 10.10.10.38
keepalive type tcp
active
service webservice1
ip address 10.10.10.31
keepalive type http non-persistent
keepalive port 80
active
service webservice2
ip address 10.10.10.32
keepalive port 80
active
!********************* HEADER FIELD GROUP *********************
header-field-group .ida
header-field .ida request-line contain ".ida"
header-field-group cmd.exe
header-field cmd.exe request-line contain "cmd.exe"
header-field-group default.ida
header-field default.ida request-line contain "root.exe"
header-field-group x.ida
header-field x.ida request-line contain "x.ida"
!*************************** OWNER ***************************
owner TDECU
content block_.ida
header-field-rule .ida weight 0
add service dummy
protocol tcp
port 80
url "/*"
active
content block_cmd.exe
protocol tcp
port 80
url "/*"
header-field-rule cmd.exe weight 0
add service dummy
active
content block_default.ida
protocol tcp
port 80
url "/*"
header-field-rule default.ida weight 0
add service dummy
active
content block_x.ida
protocol tcp
port 80
url "/*"
header-field-rule x.ida weight 0
add service dummy
active
content pcuserver
vip address 10.10.10.36
add service pcuservice1
add service pcuservice2
balance destip
protocol tcp
port 443
url "/*"
advanced-balance ssl
application ssl
active
content webserver443
add service webservice1
add service webservice2
balance destip
protocol tcp
port 443
vip address 10.10.10.30
active
content webserver80
balance destip
protocol tcp
port 80
active
!*************************** GROUP ***************************
group PCUServers
add destination service pcuservice1
add destination service pcuservice2
active
group WebServers
add destination service webservice1
add destination service webservice2
active
The problem occurs when I add the second CSS box. The synchronization works properly, but when I unplug the connection between CSS1 and the L2switch, CSS2 becomes master, but it's gigabit port does not become active.
I tried a work around of using the gigabit port and a fastethernet port, which did help some, but failover time was in the order of 1 minute or more.
What I have not tried is using a virtual router or a virtual interface, though that will probably be my next attempt.
Thank you,
Cosby A. Coleman
TCCSI
