Restricting access to VIP (using ACE module)
wim.juste
Level 3
Level 3
Dear all,
I’m trying to find out whether you could restrict access to a single VIP to only 2 different source ip addresses?
Our situation looks like:
ACE module setup in one-armed design, using NAT.
About 200 vips are defined.
I know you could restrict access using a access-list and apply it to the interface.
But I was hoping this restricting could be configured within the particular class-map / policy-map of this single VIP configuration?
Here’s also a snap-shot from our load balancer, showing (only) the single VIP configuration.
(I explicitly did not include all other 199 vip configurations)
Ps: the traffic hitting this vip is NO http traffic, but generic TCP traffic.
In advance, thanks for any feedback.
Truly appreciate it !
access-list 101 extended permit ip any any
rserver host P_ARDS_1
  ip address x.x.32.130
  inservice
rserver host P_ARDS_2
  ip address x.x.32.128
  inservice
rserver host P_ARDS_3
  ip address x.x.10.69
  inservice
rserver host P_ARDS_4
  ip address x.x.10.79
  inservice
serverfarm host P_ARDS_SF_LB
  predictor leastconns
  probe PING
  rserver P_ARDS_1
    inservice
  rserver P_ARDS_2
    inservice
  rserver P_ARDS_3
    inservice
  rserver P_ARDS_4
    inservice
class-map match-all P_ARDS_VS_LB
  2 match virtual-address 10.0.0.1 tcp any
policy-map type loadbalance first-match P_ARDS_P_LB
  class class-default
    sticky-serverfarm P_ARDS_S_LB
policy-map multi-match VIP_vlan485
class P_ARDS_VS_LB
    loadbalance vip inservice
    loadbalance policy P_ARDS_P_LB
    loadbalance vip icmp-reply active
interface vlan 101
  ip address 10.120.18.133 255.255.255.240
  alias 10.120.18.132 255.255.255.240
  peer ip address 10.120.18.134 255.255.255.240
  access-group input 101
  access-group output 101
  service-policy input MNGT_101
  service-policy input NAT_vlan101
  service-policy input VIP_vlan101
  no shutdown
rvavale
Hi Wim,
Lets says you want to restrict access to Client with Source IP 1.1.1.1 then you can configure Class-map to match on Source IP,
class-map type http loadbalance match-all Source-IP
  2 match source-address 1.1.1.1 255.255.255.255
And apply it to Policy map
  class Source-IP
With above config, for any request hitting the VIP, it will check if the Source IP matches Class-map 'Source-IP',  if it does then it will be loadbalanced if not then request will fail.
http://www.cisco.com/en/US/partner/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA4_2_0/configuration/slb/guide/classlb.html#wp1478259
Hope this helps,
Best Regards,
Rahul
