Sticky resource issue in Cisco ACE 4710
Saroj Pariyar
All,
Sticky resource usage is always at peak in one of my context in Cisco ACE 4710.Users are reporting slowness/packets drop issue frequently for the rules which has source-ip based sticky.Can high utilization of Sticky resource cause this issue ?? Also I did a lot of cisco docs reading but i didn't find what kind of resource sticky use. ?? can someone shade some lights like by sticky resource what kind of resource it is ?? is it like CPU,memory,concurrent connections,ssl connections etc etc ??
sh resource usage resource sticky
                                                     Allocation
        Resource         Current       Peak        Min        Max       Denied
Context: PROD_Apps
  sticky                    40960      40960      40960      40960          0
sesoerensen
Hi Saroj,
Would it be possible for you to share the sticky configuration of the context?
What version of code is used on the ACE?
From the looks of it, the ACE uses Ll of the available sticky resources, but is not dropping flows due to sticky at least.
Reserving sticky resources to a specific context is done using resource class maps, in the Admin context.
Cheers,
Søren
HI Sesoerensen,
I am using code version A4(2.1a).
Here's the config: But could you please let me know what kind of resources the sticky uses.By resource does it mean CPU,memory etc etc .
rserver host
  ip address
  inservice
rserver host
  ip address
  inservice
rserver redirect REDIRECT-TO-HTTPS_app_googleTV_prod
  webhost-redirection 301
  inservice
serverfarm host app_googleTV_prod
  probe TCP_16850
  rserver 16850
    inservice
  rserver 16850
    inservice
ssl-proxy service CLIENT_SSL_GOOGLETV
  ssl advanced-options HTTPS_PARAM_MAP
ssl-proxy service Server_SSL_GOOGLETV
  key GOOGLETV_PROD_KEY.PEM
  cert GOOGLETV_PROD_CERT.PEM
  chaingroup GOOGLETV_PROD_IntermedCA
sticky ip-netmask 255.255.255.255 address source app_googleTV_prod_HTTPS_STICKY
  timeout 720
  replicate sticky
  serverfarm app_googleTV_prod
policy-map type loadbalance first-match app_googleTV_prod_HTTPS_policy
  class class-default
    sticky-serverfarm app_googleTV_prod_HTTPS_STICKY
    ssl-proxy client CLIENT_SSL_GOOGLETV
policy-map type loadbalance first-match app_googleTV_prod_HTTP_policy
  class class-default
    serverfarm REDIRECT-SERVERFARM_app_googleTV_prod
class-map match-all app_googleTV_prod_HTTPS_class
  2 match virtual-address  tcp eq https
class-map match-all app_googleTV_prod_HTTP_class
  2 match virtual-address  tcp eq www
policy-map multi-match POLICY-LB-VLAN488
  class app_googleTV_prod_HTTPS_class
    loadbalance vip inservice
    loadbalance policy app_googleTV_prod_HTTPS_policy
    loadbalance vip icmp-reply active
    nat dynamic 1 vlan 488
    ssl-proxy server Server_SSL_GOOGLETV
  class app_googleTV_prod_HTTP_class
    loadbalance policy app_googleTV_prod_HTTP_policy
