Stopped a remote Blade for Backup, After backing up....
Dan Loring
After backing up a blade I went into the CM, edit Device, Admin, Virtualization, Actions, Start Blade.  It is up and running, I can ping it, but I cannot RDP to the server to verify that it is backup.  It seems like the server is shut down still.  What options do I have to restart this remote virtual server???
18 Replies 18
Dan,
Verify the virtual blade is running and the vnc server is active on the CLI of the WAAS deivce
Example output:
pdi-274-sj#sh virtual-blade 1
virtual-blade 1
config:
device cpu qemu64
device nic virtio
device disk IDE
device keyboard en-us
memory 1024
disk 20
interface 1 bridge GigabitEthernet 1/0 mac-address 00:21:D8:AB:5A:C7
cpu-list 1
no boot fd-image
boot cd-image disk /local1/vbs/virtio-drivers.iso
boot from disk
autostart
state:
running
serial console session inactive
vnc server active
no vnc client connected
current cd /local1/vbs/virtio-drivers.iso
current floppy [not inserted]
If it is running and vnc server is active, try using VNC to console to the VB; maybe RDP was disabled in Windows for some reason?
If you don't have a VNC client on your PC you can download something like TightVNC for free.
http://www.tightvnc.com/download.php
Then connect to the management IP of the WAAS device on port 1.
Mike Korenbaum
Cisco WAAS PDI Help Desk
http://www.cisco.com/go/pdihelpdesk
Here is my output from the CM.  It looks like it is booting from the cd ROM, is there a way of shutting down that option?  I have a vnc client, but was not able to connect, probabley because it is at the server setup screen???
virtual-blade 1
config:
description Needham DC
device cpu qemu64
device nic rtl8139
device disk IDE
memory 1024
disk 30
interface 1 bridge GigabitEthernet 1/0 mac-address 00:21:D8:AC:2C:6F
cpu-list 1
no boot fd-image
boot cd-image disk /local1/vbs/en_ws_2003_std_sp1_vl.iso
boot from cd-rom
autostart
state:
running
vnc server active
current cd /local1/vbs/en_ws_2003_std_sp1_vl.iso
Dan,
Stop the VB and change the boot paramter to boot from disk.
Ex.
pdi-274-sj#virtual-blade 1 stop
pdi-274-sj#conf t
pdi-274-sj(config)#virtual-blade 1
pdi-274-sj(config-vb)#boot from disk
pdi-274-sj#virtual-blade 1 start
Mike
Mike,
I applied those settings, as well as "no boot cd-image" , but it seems the server itself is still shutdown.  I have a vnc client and a RDP client and they both fail, and the server is not pinging, I was pinging the device earlier and not the server IP.  Here is my output now after putting new commands to boot from disc.  It seems the blade is started, but the virtual machine is still shutdown.......
virtual-blade 1
config:
device cpu qemu64
device nic rtl8139
device disk IDE
memory 1024
disk 30
cpu-list 1
no boot fd-image
no boot cd-image
boot from disk
autostart
state:
running
vnc server active
current cd [not inserted]
Dan,
Can you ping the Gig 1/0 interface of the WAVE?
When you attempt to connect to the VB console via VNC are you using WAVE IP or the Windows IP?  It should be the IP address of the Gig 1/0 on the WAVE on port 1.
Regardless of the state of the Windows VM I would expect you do have some output on your VNC console session.
Are you local to the WAVE or remote?  Is it possible that something is blocking your VNC session between you and the WAVE?
Yes I can ping the gig 1/0. I can also connect SSH via putty, and it is showing up in the VM in regards to acceleration and optimization.
When I try to connect to the gig 1/0 interface via VNC it just flashes and goes away, no error.  I have always just used RDP to connect to that server, but when I try to RDP it errors out and says the server is turned off.  Unfortunately I am remote to the device.  Would a reboot of the entire device be out of the question at this point?
Maybe you can try from a local PC?  Or try with a different VNC client?  You had to at one point use VNC during the initial setup of Windows, prior to enabling RDP in Windows.
I wouldn't think you would want to reload the device in the middle of the day, but certainly can try that after hours if you want.
okay, so I downloaded the tightvnc, and was able to connect, but it is just a blank screen...  Would a virtual-blade reset kick start the virtual machine, or would that not be a good command to try.
I would connect to the console with TightVNC, then issue that command and see if you get any output on the screen, maybe some errors during bootup?
If it's not operational right now/ serving clients I don't see any reason why you couldn't reset the VB.
okay so I issued the reset command and it came up with  the attached screen, basically hit F12 for a boot device, If I hit F12 I get hard drive, cd, network and floppy options, and none of them boot.  I also at this point have issued a reload command and we are back at the blank screen. any other ideas????  Am I at the point of trying to reload the image that I backed up, or are there other steps I can take before going down this road?  What are the chances the backup got pushed without corruption, or do you think the image is okay, but there is some other issue with the system?
Dan,
You can certainly try restoring your VB disk as per the instructions here:
http://www.cisco.com/en/US/prod/collateral/contnetw/ps5680/ps6870/white_paper_c11-609580.html#wp9000241
If you don't get anything after "Press F12" it would seems that the VB is not finding your virtual disk to load the OS.
Mike
Where should the virtual disc be?  If I where to go in and point it to the virtual disc what directory would it be located in?  Here is my local1 dir.(see below)  In the vbs dir there is an iso, I tried pointing the boot to that, but got no luck.  I also attached my current show virtual blade1(see bottom)  any of this obviousely out of whack??
Needham-AA(config-vb)#boot from disk
Needham-AA(config-vb)#boot cd-image disk /local1/vbs/en_ws_2003_std_sp1_vl.iso
Needham-AA#cd local1
Needham-AA#dir
      size          time of last change             name
        125052  Tue Mar 29 12:58:00 2011           UcliEvt.bak
         58752  Thu Mar 31 13:53:01 2011           UcliEvt.log
          4096  Wed Nov  3 21:18:39 2010
    actona
          4096  Thu Mar 31 12:37:28 2011
    cliTemp
          4096  Wed Nov  3 21:20:57 2010
    core_dir
          4096  Wed Nov  3 21:22:27 2010
    crash
             0  Thu Mar 31 12:48:52 2011           db-downgrade.log
          3066  Sun Jan 23 20:11:39 2011           dbupgrade.log
           634  Wed Mar 16 16:01:27 2011           diagnostic_report.txt
          1002  Wed Mar 16 16:01:27 2011           diagnostic_report.xml
          4096  Mon Mar 28 12:58:15 2011
    downgrade
          4096  Thu Mar 31 12:52:19 2011
    errorlog
          5574  Thu Mar 31 12:50:28 2011           irqbal_debug.txt
          4096  Thu Mar 31 12:51:08 2011
    logs
         16384  Wed Nov  3 21:14:31 2010
    lost+found
          4096  Wed Nov  3 21:20:55 2010
    pki
          4096  Thu Mar 31 03:26:00 2011
    sa
         24576  Thu Mar 31 13:54:15 2011
    service_logs
          4096  Wed Nov  3 21:22:25 2010
    spool
        715287  Thu Mar 31 13:51:25 2011           syslog.txt
          4096  Wed Nov  3 21:20:53 2010
    var
          4096  Fri Jan  7 07:39:39 2011
    vbs
           508  Wed Nov  3 21:20:54 2010           wdd.sh.signed
Needham-AA#sh virtual-blade 1
virtual-blade 1
config:
device cpu qemu64
device nic rtl8139
device disk IDE
memory 1024
disk 30
cpu-list 1
no boot fd-image
boot from disk
autostart
state:
running
vnc server active
The virtual disk file(s) are not exposed via the directories available on the CLI.
However, you are able to restore the disk file(s) that were previously backed up per the process listed here:
Were you able to restore your previous backup?
In the process of restoring the blade that I backed up.  Hopefully it backed up a good one and not the corrupted one that is there now.  If this process fails do you have an article that walks you through building a new blade server?
