Two GSS with Hash
jcarvalh
Hello.
I want to set up a cluster of two GSS in different Data Center.
If I use the hash method as loadbalance method does both GSS take the same decision? If I have only one GSS I can use hash to perform stickyness; my concern is if one GSS goes down does the other reply with the same answers.
Best ragards,
Joao.
Daniel Arrondo Ostiz
Hi Joao,
The hash algorithm is the same on all GSS, so, assuming all the answers are operational, the results returned by both GSS should be the same. However, be aware because once answers start going up and down, this may no longer be the case.
If you really want to ensure that both GSS retrun the same answer, then, you should configure DNS stickiness instead. In the end, that's what this feature was designed for
For more details, please check the link below:
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/gss4400series/v4.1.1/configuration/gui/gslb/guide/Sticky.html
I hope this helps
Danie
Hi Joao,
I hope this helps
Danie
Hello Daniel.
Thanks for your reply.
Joao.
