Urgent ! Router-WAAS WCCP problem
s.uslay
I have dot1q enabled 7507 connecting frame relay branch to data centre.
Core WAAS sits on a VLAN subinterface.
As soon as I enable "ip wcccp redirect 61 in" on VLAN trunked interface, I am loosing connection to the branch.
the config is here..
interface GigabitEthernet4/0/0
description Core Data Centre Trunk VLAN 3,120 to SWDC03 3/16
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
load-interval 30
negotiation auto
no cdp enable
interface GigabitEthernet4/0/0.3
description Core Data Centre VLAN
encap dot1q 3
ip address xxxx
ip wccp 61 redirect in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
ip route-cache flow
no cdp enable
standby 3 ip 10.64.205.17
standby 3 priority 150
standby 3 preempt
interface GigabitEthernet4/0/0.120
description Core WAAS VLAN120
encap dot1q 120
ip address yyyyyyy
ip wccp redirect exclude in
no ip redirects
no ip unreachables
interface Serial0/0/3.64 point-to-point
ip wccp 62 redirect in
The IOS version is rsp-jsv-mz.123-17b and WAAS version 4.0.13.I have tested this before without VLAN trunking on another router using a seperate interface and it was working.Any idea ?
thanks
5 Replies 5
Zach Seils
Level 7
Level 7
Serhat,
Are you losing all client connectivity to the branch, or just telnet/ssh access to the branch router? If it is the latter, CSCsg30875 may be an issue. Can you please clarify the extent of the connectivity loss?
Zach
Thanks Zach.Cisco SE told me that this only happens when the default gateway in WAAS is not the same as WCCP router address. I will move HSRP active interface from 6509 VLAN to WAN router and test it again. I will keep you informed.
thanks
Serhat
There is no requirement that the default gateway used on the WAE has to be the same as the IP addresses configured in the WCCP router-list. In fact, when HSRP is configured on the WAE VLAN, the default-gateway is set to the HSRP VIP, while the WCCP router-list uses the real interface IP addresses of each HSRP member.
Zach
dstolt
Looks like you are doing wccp 62 redirect in on the WAAS VLAN? The WAAS VLAN should be a dedicated VLAN and excluded from interception. Try moving 62 to the WAN interface (frame relay).
Dan
thanks guys. I will explain the problem a bit more.When WAAS sits on a seperate i/f on WAN router, it works fine. i.e "wccp redirect 61 in " on interface connecting WAN router to Data Centre and "wccp redirect 62 in" on WAN frame relay. Then I configured the i/f connecting WAN router to Data Centre as dot1q trunk and a dedicated VLAN is created for WAAS. The default gateway for WAAS is HSRP address in 6509s. The WCCP router address configured in WAAS is the loopback0 address of the WAN router. The "wccp redirect 62 in" on WAN frame relay stays same. However, " wccp redirect 61 in " carried to a new subinterface on the same access as WAAS VLAN.
All WCCP commands show that there is a connection between WAAS and WAN router, packet count goes up. However, all TCP sessions to the brach (initiated from the Data Centre) fail. I have also tested with and without "wccp redirect exclude in" on WAAS VLAN subinterface without success. Since I had to install the branch the WAAS on the weekend, I moved WAAS back to dedicated interface on WAN router. It works fine but I can not implement redundancy.
The suggestion was to make WAN router subinterface HSRP active rather than 6509 MSFCs.So WAAS talks to WAN routers loopback address and default gateway also points to the same router rather than MSFC. I have not had a chance to test this but I will test in the coming weeks. I was also suggested to use layer2 redirection on 6509 but did not have any chance to look at it closely.
thanks
Serhat
