Using port 443 in L4 policy with ACE
lukaszkhalil
Hello
I am trying to create on my ACE a VIP on a port 443 that will work in a layer 4. The real http traffic will be decrypted on the rservers.
As long as I do not use the port 443 as a VIP port everything is OK, but if I changed it to 443 I loose the communication.
Does anybody know if there is any restriction in the ACE that does not allow using the 443 TCP port for L4 traffic?
Thank you in advance
Lucas
Surya ARBY
Level 4
Level 4
No restriction. It should work. here is one of my template for that :
access-list PERMIT-ALL line 8 extended permit ip any any
serverfarm host XXX
failaction purge
predictor leastconns
probe generic-tcp
rserver SYMI-NH01 443
  inservice
rserver SYMI-NH02 443
  inservice
sticky ip-netmask 255.255.255.0 address source XXX
timeout 3600
replicate sticky
serverfarm XXX
class-map match-any XXX
2 match virtual-address A.B.C.D 255.255.255.255 tcp eq https
policy-map type loadbalance first-match XXX
class class-default
sticky-serverfarm XXX
OK, thanks.
I forgot to mention that my rservers are listening on different port then 443.
Just change the port in the serverfarm
