VM machine HA at Two Datacenters
raed dabbous
Hello All
We have a customer has the following scenario:-
1- On DC#1 has certain application and installed on VM#1
2- On DC#2 has the same application and installed on VM#2
3- He needs when the VM#1 goes down (Not the server hosting this VM), the users must have the ability to use VM#2.
How to make some thing like that?... The customer has Cat6509-E with Sup-2T.
ajayku2
If this question is related to ACE then you can achieve as follows:
ace/AJAY(config)# serverfarm host TEST-FARM
ace/AJAY(config-sfarm-host)# rserver VM1
ace/AJAY(config-sfarm-host-rs)# backup-rserver VM2
ace/AJAY(config-sfarm-host-rs)# inservice
The config will look like this :
serverfarm host 1313-GIN-GWAP-SDC-80
  rserver VM1
    inservice
  rserver VM2
    inservice standby
So in case if rserver VM1 will fail VM2 server will fulfill the request
Hope that helps.
regards,
Ajay Kumar
