WAAS CM Configuration Issue
rm2017
I have a WAE running 4.1.3 that registered successfully to the CM but is failing to pull the config from the CM (also at 4.1.3).
It shows up as activated and online, but nothing shows up under the Services column within CM - where you typically see Application Accelerator.
Debugging CMS on the edge WAE showed 'Failed to Connect to CMS configuration consumer. Unable to connect.'
Has anyone experienced this? All other WAE's in my environment have registed and been able to pull config from CM w/o issue.
dstolt
I would recommend that you try to do a cms deregister force on the accelerator, and delete it from the central manager GUI. Then try re-registering to the CM and see if that will fix the issues.
Dan
