10-07-2013 05:12 AM
One of my customers have a simple waas setup, One central manager (OI274) and one waas on the central site (OE674)(europe), two waas in China (OE574 and OE264)
Now, the central OE674 stands as "offline" on the central manager.
They are both on the same lan 192.168.1.3 and 192.168.1.4, and i can acccess them both.
I have tryed to deactivate the OE674 and activate it again, still offline.
Software version is 4.4.3a
Per Buch
Solved! Go to Solution.
10-07-2013 09:58 PM
Hey,
Did you remove it from the Central Manager and then reenable from the CLI WAAS accelerator by doing
(config)# cms enable or how did you try to do it?
If you want to analyze the possible core files generated you can open a TAC case for deeper analysis.
Jorge
Mark if it was useful then others can use it as reference in the future.
10-07-2013 06:12 AM
There are more errors.
On the mail office waas "cifsAO" is not running, and cant be restartet
Both China waas has an error "User space Core files were detected"
10-07-2013 09:58 PM
Hey,
Jorge
10-07-2013 10:59 PM
I was just deactivating / activating from central manager.
Tryed to do a
CMS enable
But got an error .. no primary interface configured.
Did a
Primary interface inlinegroup 1/0
And it is online now !
Where are the "User space Core files" ?
I guess that i can just delete them ?
/Per
10-08-2013 02:16 PM
Per,
Yes, you can delete them they should be under a folder in the main directory, please check with:
WAE# dir
size time of last change name
4096 Fri Feb 24 14:40:00 2006actona
4096 Tue Mar 28 14:42:44 2006core_dir
4096 Wed Apr 12 20:23:10 2006crash
4506 Tue Apr 11 13:52:45 2006 dbupgrade.log
4096 Tue Apr 4 22:50:11 2006downgrade
4096 Sun Apr 16 09:01:56 2006errorlog
4096 Wed Apr 12 20:23:41 2006logs
16384 Thu Feb 16 12:25:29 2006lost+found
4096 Wed Apr 12 03:26:02 2006sa
24576 Sun Apr 16 23:38:21 2006service_logs
4096 Thu Feb 16 12:26:09 2006spool
9945390 Sun Apr 16 23:38:20 2006 syslog.txt
10026298 Thu Apr 6 12:25:00 2006 syslog.txt.1
10013564 Thu Apr 6 12:25:00 2006 syslog.txt.2
10055850 Thu Apr 6 12:25:00 2006 syslog.txt.3
10049181 Thu Apr 6 12:25:00 2006 syslog.txt.4
4096 Thu Feb 16 12:29:30 2006var
508 Sat Feb 25 13:18:35 2006 wdd.sh.signed
This is the command: #delfile filename to delete the files
Jorge
