WAAS Module stops routing
romueller
Community Member
HI,
I have a strange problem. We have 6 WAAS Modules installed in C3945 Routers with the Enterprise License. The CCM ganz reach the modules do what the should do but after about 4 hours 2 of the modules stops forwarding the traffic they are not able to ping the router where they are installed BUT i can login onto the modules from outside (with telnet on port 2067). After a reload of the module (service-module sm 1/0 reload) the devices work again.. there are no LOG entries or something else what can be a hint of the problem.. we have the firmware 4.4.3 installed..
Can someone explain me what happens and how to solve it?
Thx
Robert
Jorge Bejarano
Level 10
Level 10
Robert,
You may try to get a Sysreport and open a TAC case
Jorge
