WCCP and use of Inbound/outbound ACLs
rolmarti
Hi Guys,
I was looking for some documentation regarding the flow of packet processing on a given interface, namely with use of WCCP.
I have a design requirement to enable WCCP on interfaces with inbound and outbound security ACLs, I was wondering what is the order in which a packet gets processed on an interface, does it get redirected before security inbound ACL is processed? And going outbound?
Would I need to add the Cache engine IP to the security ACLs?
I can't disable these ACLs, any gotcha's with using L2 redirection?
rolmarti
FYI I had found this:
http://www.cisco.com/en/US/prod/collateral/routers/ps9343/white_paper_c11_502351.html
Inside to outside:
1. decryption
2. input ACL
3. inspect
4. routing
5. WCCP
6. Network Address Translation (NAT) inside to outside
7. crypto (check map and mark for encryption)
8. output ACL
9. inspect
Outside to inside:
1. decryption
2. input ACL
3. inspect
4. NAT outside to inside
5. WCCP
6. routing
8. output ACL
9. inspect
