wccp web-cache works slow, slowstart
thomas.kauert
I have running CE510 working as transparent cache with c7206VXR on a separate subnet (LAN 2). Client request´s (LAN 1) need 2-3 minutes to get a web page or get a timeout. Redirect´s for wmt or mms work fine.
thomas.chen
Level 6
Level 6
Do you have the following command enabled on the CE.
http cache-miss revalidate
Also check if the following commands are present
no ip route-cache
no ip mroute-cache
If so disable this command and check how the performance of the CE is. I have seen that when the configuration has this command enabled the Cache engine wccp works very slow, but the performance improves by a large factor when this command is disabled.
mcgbic
Won't hurt if you check the Faste's duplex & speed settings. Sometimes our CE will just default back to half upon reboot. Also a bad disk may also cause slowness. Check status of all disks. "show disk detail". hope this helps
