Inbound FXO calls from Remote gateway get fast busy on CUE
Paul Dicine
Team,
I  have a customer with a UC 560 at the HQ site and 7 fxo lines. They also  have a remote site with a 2800 ISR router termination the T-1 between  the sites as well as providing 3 FXO ports for that site. Internally,  everything works, Externally any call that comes into any of the 7 HQ  FXO lines works flawlessly. Problem is any calls coming into  the 3 FXO  lines at the remote site get a fast busy or disconnected when trying to  talk to CUE.
99.9% of the time this is a codec issue... So here is what I have done....
1) Every single VOIP dial-peer has the codec g711ulaw command on it.
2) I have configured via voice service voip the allow-connections 323 to sip and sip to 323 etc
3) verified the sip CUE dial-peer..(Remember it works for all the lines attached to the box)
So  I am pretty confident I am using g711ulaw all the way through... The  only variable here is the WAN... Transfers to extensions work,  Conferences work, just anything to CUE dies....
Am  I missing something here? I will try to post a voice ccapi inout debug  if you need it, but was just wondering if anyone had any ideas on what  to check.
Team,
To add a little more to this. This is what I have further discovered.
This  only happens when i try to get to someones mailbox via the trnsfrVM  softkey or by direct transfer to VM by hitting transfer 6xxx and  transfer again or by the call coming into an extension, ringing until it  hits the timeout and then when the call tries to go to the persons VM  box, the call drops.
If  I transfer to the main VM number (399) it works. If I transfer to the  AA it works...Just seems to be individual mailboxes that get the Fast  Busy or Disconnect.
DEBUGS:
Paul Dicine
Here are the sip message debugs. Hopefully someone can help. This  debug is me calling in on the remote site FXO, hitting the TrnsfrVM  button, hitting the users extension (125) and hitting the TrnsfrVM  button again. At that point the call just hangs up. Any help is  appreciated.
Paul
021117: Oct  5 02:10:53.614: //4654/EA8AC4BA87E5/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:399@10.1.10.1:5060 SIP/2.0
Via: SIP/2.0/UDP 10.1.10.2:5060;branch=z9hG4bK1DE200C
Remote-Party-ID: "Dicine PAUL  " <2035555555>;party=calling;scre
en=no;privacy=off
From: "Dicine PAUL  " <2035555555>;tag=2B3A83C8-19C5
To: <399>
Date: Fri, 05 Oct 2012 02:10:53 GMT
Call-ID: B9C8C803-DC811E2-9DFC974A-C9095719@10.1.10.2
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 3934962874-0231215586-2279993872-0125821984
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIF
Y, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1349403053
Contact: <2035555555>
Diversion: <125>;privacy=off;reason=unconditional;counter=1;screen
=no
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 238
v=0
o=CiscoSystemsSIP-GW-UserAgent 1503 9301 IN IP4 10.1.10.2
s=SIP Call
c=IN IP4 10.1.10.2
t=0 0
m=audio 17294 RTP/AVP 0 101
c=IN IP4 10.1.10.2
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
021118: Oct  5 02:10:54.114: //4654/EA8AC4BA87E5/SIP/Msg/ccsipDisplayMsg:
Sent:
en=no;privacy=off
To: <399>
Date: Fri, 05 Oct 2012 02:10:54 GMT
Min-SE:  1800
Y, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1349403054
=no
Expires: 180
Content-Length: 238
v=0
s=SIP Call
c=IN IP4 10.1.10.2
t=0 0
c=IN IP4 10.1.10.2
a=fmtp:101 0-16
a=ptime:20
021119: Oct  5 02:10:54.118: //4654/EA8AC4BA87E5/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <399>
CSeq: 101 INVITE
Content-Length: 0
021120: Oct  5 02:10:54.134: //4654/EA8AC4BA87E5/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <399>;tag=dsf07fc022
CSeq: 101 INVITE
Content-Length: 0
Contact: <399>
Allow: INVITE, BYE, CANCEL, ACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO
Cisco-Gcid: B9C8C803-DC811E2-9DFC974A-C9095719@10.1.10.2
021121: Oct  5 02:10:54.170: //4654/EA8AC4BA87E5/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 101 INVITE
Content-Length: 184
Contact: <399>
v=0
o=CUE 11571244 2 IN IP4 10.1.10.1
s=SIP Call
c=IN IP4 10.1.10.1
t=0 0
m=audio 20512 RTP/AVP 0 101
a=fmtp:101 0-15
021122: Oct  5 02:10:54.174: //4654/EA8AC4BA87E5/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:399@10.1.10.1:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.1.10.2:5060;branch=z9hG4bK1DF14C2
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
021123: Oct  5 02:10:54.182: //4654/EA8AC4BA87E5/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:399@10.1.10.1:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.1.10.2:5060;branch=z9hG4bK1E01313
Max-Forwards: 70
CSeq: 102 BYE
Reason: Q.850;cause=0
P-RTP-Stat: PS=0,OS=0,PR=0,OR=0,PL=0,JI=0,LA=0,DU=0
Content-Length: 0
021124: Oct  5 02:10:54.182: //4654/EA8AC4BA87E5/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 102 BYE
Content-Length: 0
