09-02-2012 11:34 AM - edited 03-21-2019 09:51 AM
No problem to login as default admin/admin via WWW interface. Unfortunately, default password is not so secure.
So I added following lines to provisioning:
<router-configuration>
<Web_Login_Admin_Name ua="na">admin</Web_Login_Admin_Name>
<Web_Login_Admin_Password ua="na">2password3</Web_Login_Admin_Password>
<Web_Login_Guest_Name ua="na">guest</Web_Login_Guest_Name>
<Web_Login_Guest_Password ua="na">guest</Web_Login_Guest_Password>
</router-configuration>
Despite of it, I can login using default password (both admin and user) but not new name/password.
Also, re-downloaded configuration (either via http://.../admin/config.xml or using SIP NOTIFY) show that default user database has not been changed:
<Web_Login_Admin_Name>admin</Web_Login_Admin_Name>
<!-- <Web_Login_Admin_Password></Web_Login_Admin_Password> -->
<Web_Login_Guest_Name>cisco</Web_Login_Guest_Name>
<!-- <Web_Login_Guest_Password></Web_Login_Guest_Password> -->
Is there a special procedure to change user name/password via provisioning file ?
Debug log show nothing suspicious during parse of provisioning file ...
Somebody with "it works" experience here ?
09-13-2012 01:45 PM
Can you send me the provisioning file and the debug log that you have for this failure?
I have a spa122 and I can change the admin password via provisioning.
You can email those to me. nseto at cisco.com
09-13-2012 11:45 PM
Sent by classic email. Thank you.
Edited by: Dan Lukes on 21.9.2012 (progress report):
1. I founded bug in my configuration file -
2. Despite of it, other bug in configuration of username/password has been found. ID of bug report created by Nelson is CSCuc24784
09-14-2012 04:59 PM
I'm having the exact same problem. Also with SPA112. The fact you and I both had the problem within a couple of days gives me hope that it's caused by the latest firmware, or by something simple that's wrong with the config.
I think the rest of my config is being accepted by the ATA.
