10-12-2012 03:08 PM - edited 03-21-2019 09:53 AM
I have trouble setting up my ATA Spa 122, I can not access the web settings, I have connected my PC on the same LAN, I can only enter the Web-based Utility from the Ethernet port of the ATA.
You can set for example if my PC has IP 192.168.1.3 and 192.168.1.8 IP ATA has a?
thanks
10-15-2012 05:13 PM
The WAN side access is off by default. In the IVR, you can enter 7932 and then 1 to enable access. Also this should be changeable in the router config of the web UI when you access it via the LAN initially.
12-12-2015 11:30 PM
I tried the 7932 and it is an invalid response.
04-27-2019 02:48 PM
This problem was kicking my butt as well...
The answer is simple and frustrating... The IVR will not allow the use of 7932# option when the default password is still in place.
The fix...
1) Connect WAN to Internet port
2) Connect any PC/Laptop to the Ethernet Port ( make sure your device is set to get a DHCP address )
3) The Cisco ATA 122 will assign your device an IP ( typically 192.168.15.100 )
4) Open a browser on your PC/Laptop and go to http://192.168.15.1 and login with default user/pass which is admin/admin
5) In configuration menu change default admin pass to a new password, while you are here enable WAN admin access.
6) For sheets and giggles and to see I wasn't pulling your leg, check the IVR again, 7932# will work now! DOH!
