SPA112 - Firmware 1.3.2(014) no longer logs
tomoshimorita
After upgrading the firmware of my SPA112 to 1.3.2(014), I cannot view the kernel or system log any more.
The Log Module window shows the kernel and system services both have log enabled with a priority of Notice. Both have Local checked.  In Log Setting, the size of Log is defined as 1024 KB.
In Log Viewer, I used to be able to view the log when I set Display to anything other than "Select an Item".  It doesn't show the log any more.  I cannot even download the log.  The downloaded text file is always empty, i.e. size is 0 (zero) KB.
Am I missing anything?
Thanks in advance.
(System Information)
Model: SPA112, 2FXS
HW Version: 1.0.0
Boot Version: 1.0.1 (Oct 6 2011 - 20:04:00)
FW Version: 1.3.2 (014) May 9 2013
2 Accepted Solutions
This issue has been addressed for the upcoming 1.3.3 release. Thank you.
LicoMonch
FW Version 1.3.3 from Dec 2013 fixes the problem.
jhfrontz1
I had the same problem, so I reverted to 1.3.1 and the logging started working again; thus, it's definitely something in 1.3.2.
LicoMonch
