04-21-2014 04:20 AM - edited 03-21-2019 10:15 AM
I have several 3102 for FXO line integration with asterisk, so far so good.
The only thing I was unable to make it work, even with option:
PSTN CID For VoIP CID: yes
Was to make the CID pass to asterisk, if I check the info tab on 3102, in Last PSTN Caller:, I can see the last caller ID number.
What would I be missing?
Thanks in advanced,
Jorge Bastos,
Solved! Go to Solution.
04-22-2014 03:42 AM
It seems that "yours" PSTN is delivering CID information between first and second ring. Currently, INVITE to Asterisk is sent immediately, e.g. before the CID is known. It needs to be delayed until CID is available.
Move to section "FXO Timer Values".
Set "PSTN Answer Delay" to number (in seconds) that is slightly more than ring period on your PSTN line. Ring period is about 5 second in most countries. so I recommend you use 7 seconds here in such case.
04-21-2014 11:58 AM
Something is wrong either on SPA3102 side or in Asterisk side. You need to decide. So catch the SIP packets, it will reveal if CID is sent correctly but ignored by Asterisk or not sent by 3102 at all.
04-21-2014 12:29 PM
Hi Dan,
I'm 100% sure it's something on 3102 side, it gets the CID, but not passing it to asterisk, on asterisk logs, the CID is blank, here's the output of debug level=3 from 3102:
Apr 21 20:18:23 192.168.1.44 FXO:Start CNDD
Apr 21 20:18:24 192.168.1.44 AUD:Stop PSTN Tone
Apr 21 20:18:24 192.168.1.44 Calling:pstn@192.168.1.223:0
Apr 21 20:18:24 192.168.1.44 [1:0]AUD ALLOC CALL (port=16390)
Apr 21 20:18:24 192.168.1.44 [1:0]RTP Rx Up
Apr 21 20:18:24 192.168.1.44 CC:Ringback
Apr 21 20:18:24 192.168.1.44 [1:0]RTP Rx Dn
Apr 21 20:18:24 192.168.1.44 AUD:Play PSTN Tone 9
Apr 21 20:18:24 192.168.1.44 caller id parse number=967874111
Apr 21 20:18:24 192.168.1.44 fxo cnddwrap_feed parse ok 967874111 status=2
Apr 21 20:18:24 192.168.1.44 -- Caller ID: -- Name = (null) -- Remote Number = 967874111 -- Dialable Number = (null) -- No Number Reason = (null) -- No Name Reason = (null) -- Message Waiting = (null) -- Date and Time = 04/21 20:18
Apr 21 20:18:24 192.168.1.44 FXO:CNDD name=, number=967874111
Apr 21 20:18:24 192.168.1.44 FXO:Stop CNDD
Apr 21 20:18:24 192.168.1.44 FXO:CNDD Name= Phone=967874111
Apr 21 20:18:37 192.168.1.44 AUD:Stop PSTN Tone
Apr 21 20:18:37 192.168.1.44 FXO:On Hook
Apr 21 20:18:37 192.168.1.44 [0]FM Alert Stop RxTx (c=0025422c;a=0)
Apr 21 20:18:37 192.168.1.44 [1:0]AUD Rel Call
Apr 21 20:18:37 192.168.1.44 DLG Terminated 2e1cf4
Apr 21 20:18:44 192.168.1.44 Sess Terminated
And if I play with: PSTN CID For VoIP CID: no
I don't get any CID when calling the FXO line.
Any ideas on which parameter I may be missing?
Been reading them all but don't see anyone that could make sense to change.
04-21-2014 04:15 PM
Information I have about the issue doesn't allow me to make useful advice. Sorry. I wish someone else will help you.
04-22-2014 01:54 AM
Here's a full SIP debug from 3102, there's no CID being passed to asterisk.
What info do you need more to help me on this?
Apr 22 09:51:57 192.168.1.39
Apr 22 09:52:08 192.168.1.39 FXO:Start CNDD
Apr 22 09:52:09 192.168.1.39 AUD:Stop PSTN Tone
Apr 22 09:52:09 192.168.1.39 Calling:234184295@192.168.1.223:0
Apr 22 09:52:09 192.168.1.39 [1:0]AUD ALLOC CALL (port=16428)
Apr 22 09:52:09 192.168.1.39 [1:0]RTP Rx Up
Apr 22 09:52:09 192.168.1.39 [1]->192.168.1.223:5060(991)
Apr 22 09:52:09 192.168.1.39 INVITE sip:234184295@192.168.1.223 SIP/2.0^M Via: SIP/2.0/UDP 192.168.1.39:5061;branch=z9hG4bK-3db4974^M From: <sip:192.168.1.223>;tag=641077e0787c4294o1^M To: <sip:234184295@192.168.1.223>^M Remote-Party-ID: <sip:192.168.1.223>;screen=yes;party=calling^M Call-ID: 752eaad0-5e822c64@192.168.1.39^M CSeq: 101 INVITE^M Max-Forwards: 70^M Contact: <sip:192.168.1.39:5061>^M Expires: 240^M User-Agent: Linksys/SPA3102-3.3.6(GW)^M Content-Length: 438^M Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER^M Supported: x-sipura^M Content-Type: application/sdp^M ^M v=0^M o=- 9845 9845 IN IP4 192.168.1.39^M s=-^M c=IN IP4 192.168.1.39^M t=0 0^M m=audio 16428 RTP/AVP 0 2 4 8 18 96 97 98 100 101^M a=rtpmap:0 PCMU/8000^M a=rtpmap:2 G726-32/8000^M a=rtpmap:4 G723/8000^M a=rtpmap:8 PCMA/8000^M a=rtpmap:18 G729a/8000^M a=rtpmap:96 G726-40/8000^M a=rtpmap:97 G726-24/8000^M a=rtpmap:98 G726-16/8000^M a=rtpmap:100 NSE/8000^M a=fmtp:100 192-193^M a=rtpmap:101 telephone-event/8000^M a=fmtp:101 0-15^M a=ptime:30^M a=sendr
Apr 22 09:52:09 192.168.1.39 [1]<<192.168.1.223:5060(451)
Apr 22 09:52:09 192.168.1.39 SIP/2.0 100 Trying^M Via: SIP/2.0/UDP 192.168.1.39:5061;branch=z9hG4bK-3db4974;received=192.168.1.39^M From: <sip:192.168.1.223>;tag=641077e0787c4294o1^M To: <sip:234184295@192.168.1.223>^M Call-ID: 752eaad0-5e822c64@192.168.1.39^M CSeq: 101 INVITE^M Server: FPBX-2.11.0(11.8.1)^M Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH^M Supported: replaces, timer^M Contact: <sip:234184295@192.168.1.223:5060>^M Content-Length: 0^M ^M
Apr 22 09:52:09 192.168.1.39 [1]<<192.168.1.223:5060(467)
Apr 22 09:52:09 192.168.1.39 SIP/2.0 180 Ringing^M Via: SIP/2.0/UDP 192.168.1.39:5061;branch=z9hG4bK-3db4974;received=192.168.1.39^M From: <sip:192.168.1.223>;tag=641077e0787c4294o1^M To: <sip:234184295@192.168.1.223>;tag=as1d5df368^M Call-ID: 752eaad0-5e822c64@192.168.1.39^M CSeq: 101 INVITE^M Server: FPBX-2.11.0(11.8.1)^M Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH^M Supported: replaces, timer^M Contact: <sip:234184295@192.168.1.223:5060>^M Content-Length: 0^M ^M
Apr 22 09:52:09 192.168.1.39 CC:Ringback
Apr 22 09:52:09 192.168.1.39 AUD:Play PSTN Tone 9
Apr 22 09:52:09 192.168.1.39 [1:0]RTP Rx Dn
Apr 22 09:52:09 192.168.1.39 FXO:CNDD name=, number=967874111
Apr 22 09:52:09 192.168.1.39 FXO:Stop CNDD
Apr 22 09:52:09 192.168.1.39 FXO:CNDD Name= Phone=967874111
Apr 22 09:52:23 192.168.1.39 AUD:Stop PSTN Tone
Apr 22 09:52:23 192.168.1.39 FXO:On Hook
Apr 22 09:52:23 192.168.1.39 FXO:Stop CNDD
Apr 22 09:52:23 192.168.1.39 [0]FM Alert Stop RxTx (c=0023f2a0;a=0)
Apr 22 09:52:23 192.168.1.39 [1:0]AUD Rel Call
Apr 22 09:52:23 192.168.1.39 [1]->192.168.1.223:5060(325)
Apr 22 09:52:23 192.168.1.39 CANCEL sip:234184295@192.168.1.223 SIP/2.0^M Via: SIP/2.0/UDP 192.168.1.39:5061;branch=z9hG4bK-3db4974^M From: <sip:192.168.1.223>;tag=641077e0787c4294o1^M To: <sip:234184295@192.168.1.223>^M Call-ID: 752eaad0-5e822c64@192.168.1.39^M CSeq: 101 CANCEL^M Max-Forwards: 70^M User-Agent: Linksys/SPA3102-3.3.6(GW)^M Content-Length: 0^M ^M
Apr 22 09:52:23 192.168.1.39 [1]<<192.168.1.223:5060(433)
Apr 22 09:52:23 192.168.1.39 SIP/2.0 487 Request Terminated^M Via: SIP/2.0/UDP 192.168.1.39:5061;branch=z9hG4bK-3db4974;received=192.168.1.39^M From: <sip:192.168.1.223>;tag=641077e0787c4294o1^M To: <sip:234184295@192.168.1.223>;tag=as1d5df368^M Call-ID: 752eaad0-5e822c64@192.168.1.39^M CSeq: 101 INVITE^M Server: FPBX-2.11.0(11.8.1)^M Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH^M Supported: replaces, timer^M Content-Length: 0^M ^M
Apr 22 09:52:23 192.168.1.39 [1]->192.168.1.223:5060(368)
Apr 22 09:52:23 192.168.1.39 ACK sip:234184295@192.168.1.223 SIP/2.0^M Via: SIP/2.0/UDP 192.168.1.39:5061;branch=z9hG4bK-3db4974^M From: <sip:192.168.1.223>;tag=641077e0787c4294o1^M To: <sip:234184295@192.168.1.223>;tag=as1d5df368^M Call-ID: 752eaad0-5e822c64@192.168.1.39^M CSeq: 101 ACK^M Max-Forwards: 70^M Contact: <sip:192.168.1.39:5061>^M User-Agent: Linksys/SPA3102-3.3.6(GW)^M Content-Length: 0^M ^M
Apr 22 09:52:23 192.168.1.39 [1]<<192.168.1.223:5060(417)
Apr 22 09:52:23 192.168.1.39 SIP/2.0 200 OK^M Via: SIP/2.0/UDP 192.168.1.39:5061;branch=z9hG4bK-3db4974;received=192.168.1.39^M From: <sip:192.168.1.223>;tag=641077e0787c4294o1^M To: <sip:234184295@192.168.1.223>;tag=as1d5df368^M Call-ID: 752eaad0-5e822c64@192.168.1.39^M CSeq: 101 CANCEL^M Server: FPBX-2.11.0(11.8.1)^M Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH^M Supported: replaces, timer^M Content-Length: 0^M ^M
Apr 22 09:52:23 192.168.1.39 DLG Terminated 2b62c0
04-22-2014 03:42 AM
04-22-2014 03:42 AM
Damn!
That's it!
I've changed it to 1sec, thanks for your help!
04-22-2014 03:56 AM
Glad to hear. Consider marking thread as answered. It will help others to found solutions.
