WRP400 problem with wireless lan
streamlake
I have recently purchased a WRP400. Everything seems to work properly, wireless, ppoe wan and phone, but there is no way that I can connet 2 pcs through wireless lan. I tried both pcs with different os's (linux, win xp) so I'm sure there is no problem with them, and the work perfectly inside other networks.
I tried different parameters in router configuration and different firmwares (from 1.00.04c to 2.0) with no luck, can anybody help me?
Thanks.
Hi Franco,
Can you ping each PC?. If not, can you ping the WRP400 from any PC?
I can ping the router from any pc's and internet (through ppoe wan) works on both.
Tthe router can ping both pc's but pc's cannot ping each other.
