ACB client SDK didn't send packets
Problem ACB client SDK version: 3.2.2.1.1
didn't send packet to server and didn't establish video and audio tranfer.
And the same problem happened in "iOSFusionSDKSample" when i create call to the same destination
log
***WEBSOCKET*** SEND: {"type":"OK","callId":"CL-1ba1694c-e8d2-4752-a644-945ffc8e2b87"}
-[WebRTCHandler peerConnection:didChangeSignalingState:] called: 0
***WEBSOCKET*** SEND: {"callId":"CL-1ba1694c-e8d2-4752-a644-945ffc8e2b87","candidate":"candidate:3745682871 1 udp 2122194687 10.10.10.239 63893 typ host generation 0 ufrag fp4J network-id 1 network-cost 10","type":"ICE_CANDIDATE","sdpMid":"audio","sdpMLineIndex":"0"}
***WEBSOCKET*** SEND: {"callId":"CL-1ba1694c-e8d2-4752-a644-945ffc8e2b87","candidate":"candidate:1413180658 1 udp 2122260223 169.254.101.237 62342 typ host generation 0 ufrag fp4J network-id 2 network-cost 10","type":"ICE_CANDIDATE","sdpMid":"audio","sdpMLineIndex":"0"}
***WEBSOCKET*** SEND: {"callId":"CL-1ba1694c-e8d2-4752-a644-945ffc8e2b87","candidate":"candidate:448303106 1 tcp 1518280447 169.254.101.237 49758 typ host tcptype passive generation 0 ufrag fp4J network-id 2 network-cost 10","type":"ICE_CANDIDATE","sdpMid":"audio","sdpMLineIndex":"0"}
***WEBSOCKET*** SEND: {"callId":"CL-1ba1694c-e8d2-4752-a644-945ffc8e2b87","candidate":"candidate:2445371719 1 tcp 1518214911 10.10.10.239 49759 typ host tcptype passive generation 0 ufrag fp4J network-id 1 network-cost 10","type":"ICE_CANDIDATE","sdpMid":"audio","sdpMLineIndex":"0"}
-[WebRTCHandler peerConnection:didChangeIceConnectionState:] called: 1
-[WebRTCHandler peerConnection:didAddStream:] called
-[WebRTCHandler didSetSessionDescriptionWithError:] called
Packets received for audio:0%, video:0%. Quality:13.
Audio was requested but zero audio input has been reported
Video was requested but zero video packets have been sent
Status changing from ACBClientCallStatusInCall to ACBClientCallStatusEnded for call with id:CL-1ba1694c-e8d2-4752-a644-945ffc8e2b87
***WEBSOCKET*** CLOSE
Cannot send message until websocket is created.
Removing call with id:CL-1ba1694c-e8d2-4752-a644-945ffc8e2b87
robdoyle
Hi Matous,
Have you set up the outbound SIP server to point to the CUCM? that your sip endpoints are registered on?
You may also need to rewrite the outbound SIP URL depending on your configuration.
Both settings can be found at https://REAS_SERVER:8443/web_plugin_framework/webcontroller/admin/
Rob
robdoyle
Hi Matous,
I see didSetSessionDescriptionWithError is called.
What config values are you providing to the sample app?
The Server should be an FQDN or IP address (and not a URL).
Rob
Hi Rob,
I create ACBUC with sessionId and then in ucDidStartSession create call to destination ########@##.###.##.## with audio and video set to SendAndReceive
Another failed in log:
Waiting for call configuration before creating sdpHandler...
***WEBSOCKET*** RECV: [{"type":"CALL_CONFIG","callId":"CL-4405b837-55d7-49a8-97e4-19a5a595e324","iceServers":[]}]
CALL_CONFIG received.
CALL_CONFIG delegate <ACBClientPhone: 0x1c42c5860>
Received call configuration 1
Received call configuration for call with Trickle ICE strategy CL-4405b837-55d7-49a8-97e4-19a5a595e324
Adding ICE candidates from call configuration message to list of stun servers - 0
AVCaptureDevice device 1, Back Camera, com.apple.avfoundation.avcapturedevice.built-in_video:0
AVCaptureDevice device 2, Front Camera, com.apple.avfoundation.avcapturedevice.built-in_video:1
WebRTCHandler activated in normal mode.
ACBClientCall setCamera 2
Preview mirroring disabled for call CL-4405b837-55d7-49a8-97e4-19a5a595e324
ACBVideoCaptureSetting captureSettingWithResolution resolution=2 frameRate=30
Added outbound call to 'sip:#########@##.###.##.##', with audio:SendAndReceive, video:SendAndReceive, delegate:YES, status:ACBClientCallStatusSetup, id:CL-4405b837-55d7-49a8-97e4-19a5a595e324
STUN servers=0, TURN servers=0, total=0
Creating PeerConnection with googIPv6=true
Failed to bind EAGLDrawable: <CAEAGLLayer: 0x1c0039820> to GL_RENDERBUFFER 1
Failed to make complete framebuffer object 8cd6
Failed to bind EAGLDrawable: <CAEAGLLayer: 0x1c422f2a0> to GL_RENDERBUFFER 1
-[WebRTCHandler peerConnectionShouldNegotiate:] called
Using 640x480@30 for video
__51-[WebRTCHandler didCreateSessionDescription:error:]_block_invoke called for: offer
Session description created in call state: ACBClientCallStatusSetup - 1
Matous
robdoyle
Hi Matous,
Rob
Hi Rob,
it works now. Thank you for your help.
Matous
