Picture on hold
It is possible to change picture, when agent is on hold ? It is the picture.
robdoyle
Hi Lukasz,
The image is defined in the video.hold.image.path config item in the /opt/cisco/<version>/CSDK/media_broker/proxy.properties file...
# Video hold image path - image must be in PNG format
video.hold.image.path=./resources/hold.png
You can provide your own png file and reference it from proxy.properties. See the Expert Assist Configuration—Audio and Video Hold Treatment section in the Installation and Configuration Guide for more information.
Rob
robdoyle
Hi Lukasz,
Rob
Hi Robert,
Do you mean this changing configuration option available on the OS REMB ? not on the GUI portal ?
yes change is made on the OS REMB
