Add user with PERL
m.batts
Level 4
Level 4
I'm trying to add a user using perl and seem to be struggling, I'm quite familiar with PERL with AXL\SOAP but the REST formatting seems to be eluding me
use LWP::UserAgent;
use LWP::Protocol::https;
$LOGFILE="logfile.txt";
$USER = '<removed>';
$PASSWORD = '<removed>';
$starttime=time();
  $xml = " <?xml version=\"1.0\" encoding=\"UTF-8\" standalone=\"yes\"?>
<User>
<Alias>jdoe</Alias>
<DtmfAccessId>7890</DtmfAccessId>
</User>";
  $url="https://10.64.144.49/vmrest/users?templateAlias=voicemailusertemplate";
  $ua = LWP::UserAgent->new;
  $header = HTTP::Headers->new;
  $req = HTTP::Request->new(POST => $url,
  Content => $xml
  $req->authorization_basic($USER,$PASSWORD);
  $req->content_type('application/xml');
  print $req->as_string;
  $response = $ua->request($req);
  #print $response->as_string;
  $runtime=time()-$starttime;
  print "This script ran for $runtime seconds \n";
exit
I keep getting
HTTP Status 400 - Bad Request
      </div>            <p>                <b>                    type:
      </b> Status report            </p>            <p>                <b>messag
e:               </b> Bad Request            </p>            <p>
<b>description:               </b> The request sent by the client was syntactica
lly incorrect.            </p>        </div>    </body></html>
This script ran for 1 seconds
}        </style>    </head>    <body>        <div id="logo">            <img s
rc="/ciscologo.gif" alt="Cisco Systems, Inc." />        </div>        <div id="c
ontent">            <div id="content-header">HTTP Status 400 - Bad Request
Can't see where I'm going wrong?
regards
mark
6 Replies 6
lindborg
I'm on a Perl guy but it might help to see what's actually being sent so you can see what the body format complaint is about.  Can you run Fiddler on your client box and capture the actual header and body details to look at?
npetrele
Feel free to ignore this because my experience with REST is with other aspects of Cisco operations, not with UC, but in the past, I found I had to do something like this in REST request:
$xml = " xml='<?xml version=\"1.0\" encoding=\"UTF-8\" standalone=\"yes\"?> ... '"
Seems redundant, I know, but specifying xml= made it work.
Hi  Nicholas , tried adding
$xml="xml='<?xml version=\"1.0\" encoding=\"UTF-8\" standalone=\"yes\"?>$xml="xml='<?xml version=\"1.0\" encoding=\"UTF-8\" standalone=\"yes\"?>
same error I'm afraid
davidn#
Mark,
Doesn't matter which language you use, if you can capture and provide the actual HTTP request, we can take a look and let you know what's wrong. (Fiddler would be a good tool to use to capture it).
David
Here is my post
Sorry for the delayed reply
POST https://10.64.144.49/vmrest/users?templateAlias=voicemailusertemplate
Authorization: Basic bWJhdHRzOkJtdzc0MCEy
User-Agent: libwww-perl/5.834
Content-Type: application/xml
xml='<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<User>
<Alias>jdoe</Alias>
<FirstName>Mark</FirstName>
<LastName>Batts</LastName>
</User>
Sorted it , just removed the line
xml='<?xml version=\"1.0\" encoding=\"UTF-8\" standalone=\"yes\"?> ... '"xml='<?xml version=\"1.0\" encoding=\"UTF-8\" standalone=\"yes\"?> ... '" completely and it worked first time.
thanks for clues on this.
