03-30-2017 07:17 AM
Hi somebody can help
Do you have Android Web RTC lib libjingle_peerconnection_so.so for x86, x64 and armv8 platform?
Van.
Solved! Go to Solution.
04-10-2017 11:02 PM
Hi Van.
This is not something we currently support at this time. For best android performance we recommend using libjingle_peerconnection_so.so armv7a.
If you require support for any of the other architectures you mentioned above please direct your request to Cisco BU or your Cisco representative.
Cheers,
Rach D
04-10-2017 11:02 PM
Hi Van.
Cheers,
Rach D
