I am trying to automate configuration for MX200 - Software ce8.0.1.1e47efe.
I need to set threshold60fps for COnnector 1 in video. When I run
xConfiguration Video Input Connector 1 OptimalDefinition Threshold60fps: never
from https://<ip>/web/xapi it works fine.
However, same command executed from SSH or sent over XML API from Python as
<Configuration>
<Video>
<Input>
<Connector item="1">
<OptimalDefinition>
<Threshold60fps>never</Threshold60fps>
</OptimalDefinition>
</Connector>
</Input>
</Video>
</Configuration>
, it returns "No Match on address expression"
On SSH it gives,
*r Configuration (status=Error):
*r Configuration Reason: "No match on address expression."
*r Configuration XPath: "Configuration/Video/Input/Connector[1]/OptimalDefinition/Threshold60fps"
** end
I don't see any references for OptimalDefinition in command.xml or config.xml.
Any workarounds? Is there a way to send commands to /web/xapi from scripts?
