Cisco Jabber - initiate call in application
chapelain36
Hi, all.
We are trying to use Cisco Jabber in our research. Is there the way to initiate call in Cisco Jabber client from 3rd party application and pass to Cisco Jabber a phonenumber? Do you have any ideas?
Thank you.
With regards, Yuriy.
dstaudt
Note, DevNet provides support for the Jabber Web SDK, not the capabilities of the Jabber native clients.
However, I think you can accomplish what you describe via 'cross launching': when Jabber is installed, it creates an associated between various 'URI schemes' (e.g. 'ciscotel://xxxx') and itself in Windows, so that links that match the URL scheme will launch Jabber.  This works in much the same way that a 'mailto://xxxx' URI works.
Jabber should support the following URL schemes for making a call:
- TEL://
- CISCOTEL://
- SIP://
e.g.;
<a href="CISCOTEL://914055551212">test link</a>
This document is specific for Jabber for iPad, but discusses the various Jabber URI schemes that should exist: http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/iPad/9_x/JABP_BK_J3C828CB_00_jabber-for-ipad-admin-9-1-1_chapt…
