Cisco SDK size is more than 1.6GB
shwetac.15
Cisco framework size is around 1.68 GB for SDK Remote Expert Mobile SDK Advanced for iOS 11.5.1.10000-22.tar.gz
We have app size constraint. Can this be made smaller by any means?
racdavie
Hi Shweta
Thanks for your update. Have you attempted to build the application? I appropriate the framework is rather large but when you go ahead and build your application your compiler should reduce the size down to what is needed making the resulting application much smaller.
I hope that helps.
Cheers,
Rach D
robdoyle
Hi Shweta,
The size of the iOS SDKs have been greatly reduced for the 11.6 releases which are available at https://developer.cisco.com/site/remote-expert-mobile/downloads/sdk/
Rob
